stuck in fifth
Old Dec 29, 2004 | 08:04 AM
cmy-vtec's Avatar
Default stuck in fifth
hey whats up guys...
I changed my oil yesterday and so afterward i took my car for a little spin. I have a 1988 HF w/ a B18A and an ls tranny. I was beating on it a little on the highway and i was doing some pretty aggresive 4th to 5ths, but not any harder then i usually do it. Anyway, I had it in 4th at about 6800 rpm and went to shift into 5th and it took a little more then it usually does to get it in gear. Once I got it in fifth though it wouldnt come out. I drove for a little while, about 2 miles, and then pushed the clutch in and out and just played with the gear shifter...after a while it slipped out after i tweaked the gear selector around a bit.
Before all this my 2nd 4th and reverse were tricky to get into. I got used to it but my bro always missed those gears (not while ******* it, just putting around) but i never had problems with the odd gears (1st 3rd 5th) until yeasterday....anyideas on what happened.
I think that i just torqued my shift linkage funny and that it kind of buckled. Oh yea, 2nd 4th and reverse problems are result of my shift linkage...its welded a little crooked.
sorry so long but any ideas are welcome thanks a lot and have a great new year!
Old Dec 29, 2004 | 08:15 AM
EP3_05's Avatar
Default Re: stuck in fifth (cmy-vtec)
It sounds like the shift linkage is tweaked more than it was when you welded it. I would remove it and have it welded correctly or buy a new linkage.
Old Dec 29, 2004 | 08:21 AM
cmy-vtec's Avatar
Default Re: stuck in fifth (91civic)
thats what i thought it might be...thanks for the second opinion.
Old Dec 29, 2004 | 08:30 AM
PHOBIA's Avatar
your tranny could also be loose,thats what my problem was,as stupid as it sounds.i woud always grind second gear no matter what rpm.then i was feeling around the back and there it was 2 missing bolts and one more on the way
Old Dec 29, 2004 | 08:44 AM
cmy-vtec's Avatar
Default Re: (PHOBIA)
oh thats dangerous...
how many bolts are there that hold the tranny to the block?
ill check when i get off work. thanks again.
would that result in some movement in the shifter under heavy acceleration also?
thanks again man
Old Dec 29, 2004 | 08:47 AM
cmy-vtec's Avatar
i just saw you from napa....i used to live in vallejo for a while. My cousin still does, hes the one who does all the swaps for everyone. He also has a 1988 HF...its the Blue one that he never takes out. He just built a 240...the gold one with no front bumper and the huge fmic....just curious to see if you have seen us around. I am in boulder, co now though.... for driving but for riding (snowboarding). peace
Old Dec 29, 2004 | 05:10 PM
PHOBIA's Avatar
really wich shop does he work for? either way man im sure ive seen him,i am pretty well known around this area for my car.i think there is 8 bolts maybe i could be wrong? i never took the time to count if you know what i mean.
CptnKeifer
Nov 27, 2007 07:02 PM
snzh22
Dec 9, 2006 08:20 PM
sterjess
Jun 22, 2005 07:37 PM
korndog
Mar 11, 2005 09:20 AM
AgentUT
Apr 18, 2004 06:39 PM
