Need help installing a driveshaft
Hi everyone,
I'm installing the passanger side driveshaft on my 94 integra GSR. I have already taken the old one out but I can't get the new one to "Click" into place in the differential. Help!
Put some grease on the circlip to keep it centered then make sure it is going in straignt then beat it in with a dead blow hammer(plastic).
Thanks for the help guys. I'll try to do that tonight since I'm at work right now. I just have another quick question. Should I put the differential side in first and then the wheel side or the other way around. What would be easyer?
I always install the inboard joint first, and then put the outer joint into the hub and install the axle nut last.
ivanson
Jun 29, 2005 06:53 PM
