I Need Serous help here
I just purchased a 1990 LS two weeks ago and am putting a newer ls motor. NOw this is my delima i found a gsr vtec (of course) head. And was thinking about an ls/vtec swap the thing is i have no clue of wut that exactly intails any and all help will be greatly appriciated. How much would this cost? what are the benefits? and how long would it take? any info on this and more i need to know everything asap thanks. Since i'm a new member i am limited to my responses....thx
Welcome to Honda-tech. Since you are limited with your responses....I will try to help with two pieces of advice.
1. Use the search button. Ls/Vtec is discussed A LOT here. A simple search using the words "lsvtec" or "ls-vtec" or "ls/vtec" or anything else you can think of such as "vtec head", etc will yield tons of results. Since you are limited with your posting/responses, this should give you ample reading time for all the posts that will come up during the search.
2. Make sure you title your threads better. "I need serious help here" doesn't tell us anything. Everyone needs serious help here. You need to post, "Beginner LS/Vtec questions" or something to that effect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted95teg »</TD></TR><TR><TD CLASS="quote">go with the gsr vtec
Did you read? All he has is the head.....and that's what he's planning to do with it. An LS/Vtec setup.
</TD></TR></TABLE>Did you read? All he has is the head.....and that's what he's planning to do with it. An LS/Vtec setup.
ILOVEMYHONDA206
May 18, 2008 01:26 AM
K20BigBlock454
Aug 1, 2003 02:44 PM
