running wires under carpet
does anyone know where i can find any articles on how to run wires under carpet? would i have to completely remove the carpet from te car, run the wiring, and then put the carpet back on?? i have a DC integra. please help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noob with an RS »</TD></TR><TR><TD CLASS="quote">does anyone know where i can find any articles on how to run wires under carpet? would i have to completely remove the carpet from te car, run the wiring, and then put the carpet back on?? i have a DC integra. please help.</TD></TR></TABLE> The only wires you would need to run "under the carpet " would be the RCAs, [if we are talking car audio] and they can and should be run down the center of car, you only need to remove console to do this, all other wire, [ power. trigger and speaker wire] can be run in the "wire tracks" under the rocker panel step trim on the left and right of the car.
94
94
how am i going to run my RCAs from the trunk to through the center console without letting the wires being seen? by going through the center console, wouldn't the RCA be shown between the center console and the rear seat? or will i be able to tuck the RCAs under the carpet once i have taken the center console off?
if youre going to take the center console out, you might as well take out your passenger seat and rear seat bottom. that way you'll have room to work and you can easily run the RCAs under the carpet through the center and under your rear seat to the trunk.
something like that shouldn't take you more than 2-3 hours your first time.
you wont need to remove the carpet. but you might need to pop off the plastic sill (on whichever side you took the front seat out) so you can get to the wire tracks that fcm mentioned.
its really not hard and you'll feel lots better about running the wires clean and out of site.
if you ask me the hardest part was taking out the center console
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noob with an RS »</TD></TR><TR><TD CLASS="quote">how am i going to run my RCAs from the trunk to through the center console without letting the wires being seen? by going through the center console, wouldn't the RCA be shown between the center console and the rear seat? or will i be able to tuck the RCAs under the carpet once i have taken the center console off?</TD></TR></TABLE>As H.Gz said you will have to remove rear seat, and removeing the pass. seat will make it a lot easier to do the wireing, and you will not have to remove the carpet, the wire tracks will be apperant when you remove the sill trimplates, [rocker panel covers]
94
94
mikess06
Audio / Security / Video
Mar 22, 2008 12:48 PM
