Del Sol AC Bracket ?
Old Dec 28, 2004 | 11:49 PM
teamm_AP1's Avatar
Default Del Sol AC Bracket ?
I'm going to be swapping a B-series very soon. I have a 1999 HOnda Civic Hatch and I want to retain my A/C. I know that i will need a del sol ac bracket #: 38930-P54-000.
My questions are.... are the del sol AC brackets bare? or does it come the pulley? What will i need?
Thanks in advance!
Old Dec 29, 2004 | 12:38 AM
teamm_AP1's Avatar
bump
Old Dec 29, 2004 | 03:46 AM
dwnthehatch's Avatar
Default Re: Del Sol AC Bracket ? (MiSCHiEF_EK)
They come with no tensioner. Use your old one.
Old Dec 29, 2004 | 08:21 PM
teamm_AP1's Avatar
Default Re: Del Sol AC Bracket ? (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">They come with no tensioner. Use your old one.</TD></TR></TABLE>
thanks!!
Old Dec 29, 2004 | 09:16 PM
eK9aT10pSi's Avatar
just fyi, your also going to need the rear si motor mount. [if u already know it, cool. i just mention it cause ive done a swaps before and once i forgot about that, lol ]
Old Dec 29, 2004 | 09:51 PM
Built Beast's Avatar
Default Re: Del Sol AC Bracket ? (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">just fyi, your also going to need the rear si motor mount. [if u already know it, cool. i just mention it cause ive done a swaps before and once i forgot about that, lol ]</TD></TR></TABLE>
and Si driver side mount, the part that bolts to the motor. different from d and b
Old Dec 30, 2004 | 01:25 AM
teamm_AP1's Avatar
Default Re: Del Sol AC Bracket ? (R33CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R33CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">and Si driver side mount, the part that bolts to the motor. different from d and b</TD></TR></TABLE>
cool thanks for all the input. luckily i can reuse all the mounts with this swap so yeah.. i only need the del sol ac bracket.
Old Dec 31, 2004 | 10:35 PM
eK9aT10pSi's Avatar
forgot abou thtat, thanks, lol
Old Jan 1, 2005 | 12:10 AM
ICU's Avatar
ICU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiSCHiEF_EK &raquo;</TD></TR><TR><TD CLASS="quote">
cool thanks for all the input. luckily i can reuse all the mounts with this swap so yeah.. i only need the del sol ac bracket. </TD></TR></TABLE>
You can also use a CRV ac bracket. I got one from a junkyard for like $20. It works just the same
Old Jan 1, 2005 | 05:20 PM
teamm_AP1's Avatar
Default Re: Del Sol AC Bracket ? (ICU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICU &raquo;</TD></TR><TR><TD CLASS="quote">You can also use a CRV ac bracket. I got one from a junkyard for like $20. It works just the same </TD></TR></TABLE>
Really? Is the CRV bracket the same size as the del sol AC bracket?
Old Jan 1, 2005 | 09:26 PM
BANting's Avatar
Really? Is the CRV bracket the same size as the del sol AC bracket? </TD></TR></TABLE>
yea i have a brand new one for sale if your interested.
Old Jan 2, 2005 | 12:53 AM
teamm_AP1's Avatar
Default Re: Del Sol AC Bracket ? (doc_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doc_vtec &raquo;</TD></TR><TR><TD CLASS="quote">yea i have a brand new one for sale if your interested. </TD></TR></TABLE>
PM SENT
Old Jan 2, 2005 | 01:04 AM
Achenar's Avatar
The driver side mount is the same from the 99/00 B16 and 99/00 D16.
The front tranny mount bracket, however, is not the same.
For those keeping score, that means you need 3 NEW BRACKETS to swap a B16 from a D16:
* Front Driver's-side engine / AC Bracket
* Rear Engine bracket
* Front Tranny bracket
The following mounts / Brackets can be re-used:
* Top Tranny
* Driver's-side engine
-a
Old Jan 9, 2005 | 10:37 PM
b 1 6 a 2's Avatar
Can you kindly give me the correct part number for this part, and how much are you selling it for?
Old Jan 10, 2005 | 12:24 AM
teamm_AP1's Avatar
Default Re: Del Sol AC Bracket ? ([civic])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [civic &raquo;</TD></TR><TR><TD CLASS="quote">]Can you kindly give me the correct part number for this part, and how much are you selling it for? </TD></TR></TABLE>
i'm not selling anything.
Old Jan 10, 2005 | 11:59 AM
b 1 6 a 2's Avatar
I was actually quoting doc_vtec
Old Jan 10, 2005 | 02:24 PM
ICU's Avatar
ICU
Yes, I believe its a p7j bracket. I have it on my B18c5 in my EK and it works perfect. I got it at a junkyard for like $30. Not bad.
ATrin
12
Jul 22, 2006 08:47 AM
XkjeldorX
Jun 7, 2006 06:09 PM
wizzards581
18
May 1, 2004 10:27 PM
Poey2
Mar 17, 2004 07:26 AM
eg6sir-s
May 12, 2003 09:32 AM
