need help with aftermarket tach
i need help wit my monster tach i need to know where the blue wire goes in my 91 dx hatch i dont have a stock tach so i need a tach so yea thanx in advanced
i had the same exact problem exept mine is a 90 dx hatch... what kindof tech are you installing, the way i set it up is i put it in the middle of my dash so it wasnt so godam obvious to other drivers but better options for mounting and i think on out cars there's wireing for a clock that if you take the top center vents out a constant, ignition and ground should all be there then you run the last wire up to your distributer...hope that helps...!!!
Needs to be About 20% Cooler
on the 2 pin plug on the dizzy the blue wire is the tach signal. u could also see if it goes to ur gauge cluster then u dont have to go thought the firewall
