JDM turn signal bulb
Old Dec 28, 2004 | 10:21 PM
SagaGSR's Avatar
Default JDM turn signal bulb
my turn signal bulb has burnt out, wats the bulb number to replace it?
i went to my local pep boys and tried to look it up, it says 1157, however that is a dual filament for the usdm integra. i tried it out anyway to see if it works, and it wont fit into the socket
help please! this hyper blink is killing me!
Old Dec 28, 2004 | 11:42 PM
Gooner's Avatar
Default Re: JDM turn signal bulb (SagaGSR)
You could always use this as an opportunity to move to LED which are availbale after market!
Old Dec 29, 2004 | 04:40 AM
Bbasso's Avatar
Did you look at the bulb you pulled out?
they sometimes have the # stamped right on the base.
Old Dec 29, 2004 | 05:56 AM
mugenracer's Avatar
There are two types of turn signal bulb, one has the two pins opposite each other and the other has the pins offset to each other. I replaced one of mine not so long ago and AFAICR its the one with the two pins opposite each other. However of you have a bulb with pins offset to each other then you can shave one of them down and it will still fit and lock into the holder
Old Dec 29, 2004 | 07:17 AM
six_speed's Avatar
buy a regular 1156 and cut/grind(nail clipper/something that can cut small stuff) one of the protruding alumnium pin and push it in and be happy
Old Dec 30, 2004 | 02:38 PM
integra_type-r's Avatar
i baught the wrong kinda bulb but i sanded the sides down...it fits perfectly
it blinks hella fast tho...i kinda like it like that
Old Dec 30, 2004 | 02:45 PM
Bbasso's Avatar
Default Re: (Integra_Type-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_Type-R &raquo;</TD></TR><TR><TD CLASS="quote">i baught the wrong kinda bulb but i sanded the sides down...it fits perfectly
it blinks hella fast tho...i kinda like it like that</TD></TR></TABLE>
Watch out, I had a turn signal bulb blink double speed and got a ticket, Many years back.
Old Dec 30, 2004 | 05:38 PM
DragII's Avatar
25 Year Member
Default Re: (Bbasso)
I have 2 jdm bulbs laying around, I'll sell them to you for $50 bucks each.
sipaboy
Honda Fit
Mar 5, 2019 09:03 PM
SpokaneSpeed
May 7, 2013 04:57 PM
Acura_DreamiN
Nov 20, 2010 07:02 PM
2k1_ITR_0736
Feb 13, 2003 09:53 AM
BoM
Jul 24, 2001 09:10 AM
