Setting timing without engine started
Old Dec 28, 2004 | 09:14 PM
1987CRXSi's Avatar
Default Setting timing without engine started
How do you set timing without starting the car? I'm gonna check the distibutor screw first, but if that isn't the problem, I'm gonna check to see if the timing is off. (I'm referring to the problem I posted about a few days ago......car won't start and is backfiring......can't seem to find that post tho)
I searched but I couldn't find a direct answer. My dad is a mechanic so I can get his help, but I'd like to at least have an idea of what I'm doing for myself.
Old Dec 28, 2004 | 10:18 PM
1987CRXSi's Avatar
Default Re: Setting timing without engine started (1987CRXSi)
dropping quickly.....anyone know?
Old Dec 28, 2004 | 10:41 PM
travis's Avatar
Cam timing or ignition timing? I don't remember the other thread.
Old Dec 29, 2004 | 05:34 AM
slowpokesi's Avatar
Default Re: Setting timing without engine started (travis)
what motor is this? if its dohc check the timing belt to make sure it hasnt jumped a tooth,
if that is good, then you really cant do anything else without starting the motor and using a timing gun.
Old Dec 29, 2004 | 06:30 AM
fireant's Avatar
Default Re: Setting timing without engine started (slowpokesi)
I would think it could be done, as long as you know position the #1 cylinder should be in when the markers align on the belt and block.
Old Dec 29, 2004 | 07:12 AM
CUSTOMCONNECTION's Avatar
https://honda-tech.com/zerothread?id=1094547 theres ur post...
Pancho2193
Mar 13, 2013 10:38 AM
ascarberry
Apr 21, 2011 03:46 PM
slow-ef
Mar 26, 2009 10:53 AM
jakscivic
11
May 1, 2006 08:36 PM
