Help me Install a ITR 25mm front sway bar on my '92 VX with the ITR 22mm in the rear already install
Old Jan 6, 2002 | 11:54 PM
ESCALVANTE's Avatar
Default Help me Install a ITR 25mm front sway bar on my '92 VX with the ITR 22mm in the rear already install
I would really appreciate it if you would tell me how to install the front sway bar (ITR 25mm) on my '92 VX.
I already have the 22mm ITR rear sway bar installed with both the Beaks and the Prothane mounting kits so I would like to add the front bar to make the handling more neutral.
Any information would be greatly appreciated. TIA
Old Jan 7, 2002 | 12:23 AM
Looose_R's Avatar
Default Re: Help me Install a ITR 25mm front sway bar on my '92 VX with the ITR 22mm in the rear already ins
i have an itr steering steering rack with a bar already on it if your interested , btw its RHD....real cheap price!
Old Jan 7, 2002 | 12:36 AM
ESCALVANTE's Avatar
b20bastard: No thanks, I already have the bar with all mounting brackets and the ITR steering rack would suck on my '92 VX because:
1) It doesn't turn to the left all the way like my stock steering rack and that means that I would have to do 3 point U-turns in small streets.
2) I would have to keep it lubricated with power steering fluid
3) It would leak all over my engine bay because I wouldn't know how to cover up the nipples to the power steering fluid lines.
Would you please Email me pics of that fresh white EG in your avatar? I have a white VX. Thanks in advance.
Old Jan 7, 2002 | 08:32 AM
jeff652's Avatar
Remove VX LCA's
Remove Downpipe
Install swaybar
Install downpipe
Install Integra LCA's
and most importantly
BUY A HELMS
Old Jan 7, 2002 | 01:13 PM
ESCALVANTE's Avatar
jeff652: Thanks for the information and I never thought I had to remove the downpipe. I've already got the JDM ITR LCAs at all four corners and where can I get a Helms manual.
Old Jan 7, 2002 | 01:30 PM
RyanR's Avatar
http://www.helminc.com
[Modified by 97TypeR_9, 2:31 PM 1/7/2002]
Old Jan 7, 2002 | 01:48 PM
jeff652's Avatar
The swaybar snakes above the exhaust stuff, and actually ow that I think abou it the linkage too, so you have to remove at least one end of the linkage. Not that big of a deal, but the helms makes it very clear . . .
ESCALVANTE
Jun 7, 2002 11:48 AM
ESCALVANTE
Jan 4, 2002 12:38 PM
ESCALVANTE
Jan 3, 2002 11:44 PM
