will spraying nitrous oxide on carbon fiber, break the CF ?
Old Dec 28, 2004 | 07:17 PM
Dan GSR's Avatar
Default will spraying nitrous oxide on carbon fiber, break the CF ?
im wondering if nitrous oxide, sprayed in close proximity or in direct contact with carbon fiber, would cause the resin and CF to crack, and break
Old Dec 28, 2004 | 09:51 PM
boostaddict.com's Avatar
Default Re: will spraying nitrous oxide on carbon fiber, break the CF ? (Dan GSR)
question....is it because you have a carbonfiber intake and u wanna use nitrous??
b18crx
Old Dec 29, 2004 | 04:31 AM
Dan GSR's Avatar
Default Re: will spraying nitrous oxide on carbon fiber, break the CF ? (boostaddict.com)
something like that
Old Dec 29, 2004 | 08:57 AM
JSR's Avatar
JSR
Purging wit a carbon fiber hood?
Old Dec 29, 2004 | 09:18 AM
cjohnson_2's Avatar
I would think it would be ok. I know its pretty cold when it shoots out but the amount of time that it would be incontact would probably be ok.
Old Dec 29, 2004 | 11:38 AM
u will have no problems man.......itll be 100%ok... my friend sprayed on his hood to check it out.....no probs.
b18crx
Old Jan 2, 2005 | 06:18 PM
vtec69's Avatar
let me borrow your new toys and ill test them out for you to see if they can stand up to n02
Old Jan 2, 2005 | 07:04 PM
HR-1320's Avatar
Default Re: will spraying nitrous oxide on carbon fiber, break the CF ? (vtec69)
I don't think it will survive your first intake backfire. If you spray you will eventually have one.
Old Jan 2, 2005 | 07:34 PM
Dan GSR's Avatar
Default Re: will spraying nitrous oxide on carbon fiber, break the CF ? (2.0Coupe)
im not concered about pressure, only cold temperature
teg_dc2
Oct 10, 2008 06:29 AM
eg6rider
Jan 10, 2006 06:11 AM
Timpey09
Oct 5, 2005 01:07 PM
ludelvr
Jan 1, 2003 10:29 PM
DocV
Feb 10, 2002 12:05 AM
