Integra Jdm headlight installation and wiring diagram *pics included*
I Think I'm TOO White For This Thread
hello people some of you have seen the project i have taken on this thread https://honda-tech.com/zerothread?id=1095696 Now i got a jdm front end but the harness has been cut i was wondering if you guys could help me connect the lines? here is a pic i made of what my car looks like the bottom left are wires someone cut on my car. i think they are the turn signal wires. please help me and here are some pics.
Wiring headlight pic
Back side of the headlight
Turn indicator on headlight
sidemarker on fender
cut wires on chassis
headlight connectors
You can test each wire with a 12volt battery on the headlight assembly. The black wire is ground then go to green red and so on. If you have a test light you can test the wires on the car harness each one. Low beams high beams so on
I have pics with connecters if needed if that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ef9ee2 »</TD></TR><TR><TD CLASS="quote"> You can test each wire with a 12volt battery on the headlight assembly. The black wire is ground then go to green red and so on. If you have a test light you can test the wires on the car harness each one. Low beams high beams so on
I have pics with connecters if needed if that helps</TD></TR></TABLE>
i did the same thing and i hooked up my fog lights to my running lights so it keeps clutter out.
DC2tuner
Dec 28, 2004 10:20 PM
