only have 1 spark from coil
Old Dec 28, 2004 | 01:02 PM
dirtracer's Avatar
Default only have 1 spark from coil
I put this motor in & it started right up. had to take it out to change cluch.Now it won't start. Ive tried 3 different coils, dist, and just tried the relay under the dash.Still have the same problem Need some imput.
Old Dec 28, 2004 | 01:18 PM
Luisito825's Avatar
Default Re: only have 1 spark from coil (dirtracer)
you should you got the firing order correcT?
Old Dec 28, 2004 | 06:06 PM
dirtracer's Avatar
Default Re: only have 1 spark from coil (ogbusboy)
I do believe I do But I don't always go to TDC. I've never had a problem with that I'll check tommorow.
JDMSiCC209
May 3, 2010 04:24 AM
dan89crxsi
Feb 10, 2007 02:44 PM
my2sons
22
Feb 8, 2005 08:17 AM
92B20GSR
Feb 19, 2004 11:36 AM
