d16z6 dizzy work on a d15b7?
Old Dec 28, 2004 | 11:46 AM
Honda Sport's Avatar
Default d16z6 dizzy work on a d15b7?
tried a search but came up with nothing. I'm wondering if a d16z6 dizzy will work on a d15b7 motor.
dilemma: everybody has a d16z6 dizzy but no d15b7 dizzy. the coil on my lil bro's car burned out so I need a coil for a d15b7. since EVERYBODY has a d16z6 dizzy, j/w if I can get it to work. OR...if you guys have a d15b7 coil you wanna sell me, PM me. TIA!
Old Dec 28, 2004 | 12:33 PM
jspresso's Avatar
Default Re: d16z6 dizzy work on a d15b7? (Honda Sport)
yes will work but youd either have to bolt it on outside the holes or take a grinder and grind off the hole mounts that stick out, i know it sounds ghetto but it works trust ive done it
Old Dec 28, 2004 | 01:10 PM
Calvinator's Avatar
like he said, it would work, but it won't bolt up directly. Only 1 of the bolts would line up without modification.
All D series distributors fit directly besides the d15z1/d16z6/jdm d15b and of course if you get a obd2 dizzy, you have to change harnesses.
Old Dec 28, 2004 | 01:21 PM
JapJunkie's Avatar
Default Re: d16z6 dizzy work on a d15b7? (jspresso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspresso &raquo;</TD></TR><TR><TD CLASS="quote">yes will work but youd either have to bolt it on outside the holes or take a grinder and grind off the hole mounts that stick out, i know it sounds ghetto but it works trust ive done it </TD></TR></TABLE>
any1 have pics of this done right??? Im buying a wanabe mini-me from this guy who couldnt get it to work,but i know i can, Anyways he tried to do this to an A6 dizzy and you peeps should see it
Old Dec 28, 2004 | 06:12 PM
so just mod it to work with the mounting bracket? it'll work without any CEL's?
Old Dec 29, 2004 | 03:54 PM
jspresso's Avatar
Default Re: (Honda Sport)
just take a grinder and where the holes are cut the bolt loops right off it take s like 5 minutes
Old Dec 29, 2004 | 03:57 PM
BauleyCivic's Avatar
Risky Business
Default Re: (jspresso)
B7 Coil - http://www.slhondaparts.com/br...EC%29
30510-PT2-006
Z6 Coil - http://www.slhondaparts.com/br...EC%29
30510-PT2-006
They are the same part #'s, the Z6 coil will work fine in the B7 dizzy. The housings themselves are different, and you'll have to dremel out the holes on a Z6 dizzy to get it to fit a B7.
Old Dec 29, 2004 | 09:26 PM
awesome guys. thanks for the help!
Old Dec 30, 2004 | 11:09 AM
I did some research and looks like these coils are all the same, just a heads up for you guys.
905 100 Acura Integra 1992 - 1997 Ignition Coil 92-97
905 100 Acura Integra GS-R 1992 - 1993 Ignition Coil
905 100 Acura Integra GS-R 1994 - 1998 Ignition Coil
905 100 Honda Accord 1990 - 1991 Ignition Coil 90-91
905 100 Honda Accord (4 Cyl.) 1998 Ignition Coil 1998 DX
905 100 Honda Accord (4 Cyl.) 1999 - 2000 Ignition Coil 99-00 DX
905 100 Honda Accord Wagon 1990 - 1991 Ignition Coil 90-91
905 100 Honda Civic 1500 1992 - 1995 Ignition Coil
905 100 Honda Civic 1600 1992 - 1995 Ignition Coil 5100
905 100 Honda Civic 1600 1996 - 2000 Ignition Coil
905 100 Honda Civic Del Sol 1993 - 1995 Ignition Coil
905 100 Honda Civic Del Sol 1996 - 1997 Ignition Coil
905 100 Honda CR-V 1997 - 2001 Ignition Coil
shocker911
Sep 14, 2015 10:44 AM
smittie152
Mar 11, 2009 04:34 PM
project92ex
Oct 31, 2008 02:35 PM
illusive503
Oct 12, 2006 11:58 AM
allturbohonda
May 7, 2004 08:53 AM
