What bottle to use
Old Dec 28, 2004 | 11:30 AM
Superman137's Avatar
Default What bottle to use
ok here in a couple of weeks I'm planning to get a nos bottle well I'm thinking about getting the zex kit for it but i'm tryin to figure out which one is safer dry or wet but I was wondering which one of do u think is safer
Old Dec 28, 2004 | 01:37 PM
iam7head's Avatar
Default Re: What bottle to use (Superman137)
I wouldnt say safer, but wet kit have a better misture then dry kit, and it's not that much more expensive then dry, get a wet kit instead
as far as brand goes, it's pretty much up to up
and since you asked
NX>NOS>ZEX
most of the new kit have a magic computer box so you wouldnt be melting your piston left and right.
Bottle warmer is a good investment, but dont get the zex one because it seems to be faulty all the time
research more before you put the kit on, stuffs like A/F ratio, launch RPM, shift point, red line, fuel pressure ,etc
Oh..btw how much your local place charge for a lb?
Old Dec 30, 2004 | 03:45 PM
Default Re: What bottle to use (iam7head)
I talked to a local shop and they were telling me that zex is the best thing on the market rite now so what is really the best and one of my friends that has zex says the dry is better but so far I'm leaning toward wet but still havent found what brand I want
Old Dec 30, 2004 | 03:52 PM
SlammedAccord96's Avatar
Zex is the easiest to install in my opinion, you basically run the line for the bottle from the trunk to under the hood, tap a few wires, and put the nozzle in the intake tract somewhere.
About wet vs. dry, wet is much safer because as it adds more nitrous, it's adding fuel as well to compensate for it. So you don't have to worry about running too lean, or detontating, etc.
I'd go for a NX or NOS wet kit personally, but ZEX is the easiest to install. Good luck!
Old Dec 31, 2004 | 07:04 AM
Default Re: What bottle to use (SpeedFreak03)
thanks dude I'm going to go with the nx wet kit I'm goin to order it next week or the week after spraying a 75 shot
Old Dec 31, 2004 | 02:20 PM
raceACCORDingly's Avatar
ive been running a nx kit for about 2 yrs. its great.
the dry vs wet thing it really personal preference. i myself am WET kit biased. i know plenty of people that have been running dry kits without a problem, remember nitrous doesnt blow motors, the drivers using it do.
i am wet kit biased because
a) has its own fuel solenoid and doesnt rely on manipulating the (fpr vacuum) fuel pressure and injectors.
b) although honda manifolds dont take to well to fuel flowing through them i still trust the fuel and nitrous atomization (mixing) a wet kit does compared to a dry kit spraying only nitrous and using the injectors add fuel to the mix. some people say dry kits have a tendency to lean out cyl #1 due to uneven nitrous/fuel atomization. i dont have any experiece cuz ive never owned a dry kit but ive read a few people that had this happen.
c)out of all the kits ive seen/installed the NX solenoids look to be of superior quality.
d)later down the line if you decide to get serious with nitrous and you can easily convert a wet single fogger kit to a direct port or plate kit(wish they made one for the F/H series) easily.
d) wet kits are much easier to tune with the ability to manual adjust the FPR fuel pressure and/or changing fuel jets etc etc...
zex dry kit is a good kit, great for starters, real easy to install but theres not much left for serious tuning. zex also makes a wet kit but i havent had a chance to check it out yet, im sure it still has the big purple barney box though.
DBoost
Mar 28, 2006 10:25 AM
boostincoupe
Jul 21, 2003 10:47 AM
KoRE
Mar 22, 2003 10:06 AM
Double 06
Jun 3, 2002 08:31 PM
EGkTiOn_CiViC
May 31, 2002 10:26 AM
