OEM GSR Header better than LS ?
Old Dec 28, 2004 | 05:18 AM
X2BOARD's Avatar
Default OEM GSR Header better than LS ?
Has anyone measured the primaries or Secondary/Collector ?
Would switching from a stock LS header to a stock GSR header result in any gains ?
Old Dec 28, 2004 | 06:08 AM
B18ls*RAYON's Avatar
Default Re: OEM GSR Header better than LS ? (X2BOARD)
even better question, will it fit?
Old Dec 28, 2004 | 06:17 AM
X2BOARD's Avatar
Default Re: OEM GSR Header better than LS ? (B18ls)
For sure it will bolt to the head... a slight cut and weld will have it meet the B pipe... that's not a problem.
Any one know about power gains or at least if the primary or collector on the GSR is bigger ?
Old Dec 28, 2004 | 06:25 AM
DontBlink's Avatar
it the primary on the gsr is a little larger than the ls(1mm) also where the 2 haves meet it is also a little larger(1.75 for the vtec manifold, i forget the ls measurement but its just a hair smaller). the gsr downpipe(second half) wil be 2 short to bolt up to a ls exhaust/cat plus the gsr uses the primary 02 in the front part of the car rather than the downpipe so that will have to be added. if you want a dirct replacement look for a used usdm type r exhauxt manifold. thats what i got it runs a little better according to the butt dyno, i dont have any real dyno numbers.
Old Dec 28, 2004 | 06:30 AM
sPaRk'iT's Avatar
I use to ran a full gsr header catback on my Ls, I dont think there's any differnece in power gain.
Old Dec 28, 2004 | 06:37 AM
X2BOARD's Avatar
Fitment is not an issue here guys.... just wondering on the sizes... thanks for the input.
Old Dec 31, 2004 | 04:25 AM
X2BOARD's Avatar
anyone else ??
Old Dec 31, 2004 | 05:18 AM
IntEGNYC's Avatar
Default Re: (X2BOARD)
if there are any differences, it woudl be minor. I 'd recommend getting an aftermarket 4-1 header for more breathing in the upper rev region.
Old Dec 31, 2004 | 05:22 AM
X2BOARD's Avatar
Default Re: (IntEGNYC)
The question is not for me... it's for someone else w/ an LS. I need something that can flow much more than stock...
Old Dec 31, 2004 | 07:17 AM
Padawan's Avatar
Darth ModerVader
Any improvement it possibly provided would definitely not be worth the time, effort, or cost of installing it (and I'm not even confident there would be a measurable improvement anyway). If he's looking for a cheap OEM "upgrade", the USDM ITR manifold will bolt right up, and would be the highest-performace (if you can call it that) option out of stock USDM Integra manifolds. That being said, even the ITR manifold probably isn't worth the time of swapping out, but at least it's a direct bolt-on solution that requires no additional modifications. Out of curiosity, why does this individual want to swap to another stock manifold?
Old Dec 31, 2004 | 07:41 AM
X2BOARD's Avatar
Default Re: (Padawan)
Thanks for the suggestions, but I'm not looking for suggestions.... I just wanna know about the gsr vs ls. I have the gsr stocker and will prolly throw on an itr manifold soon. A buddy with an LS mani would like to use my old gsr unit if it's worth any kinda power.
Old Dec 31, 2004 | 07:49 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">A buddy with an LS mani would like to use my old gsr unit if it's worth any kinda power.</TD></TR></TABLE>as the others have stated, its not worth it- the difference in power between the two, if any, is neglible.
JDMjoe86
Mar 21, 2007 04:45 PM
jrzy2nR
Jan 29, 2006 05:58 PM
hamburgler
Jan 13, 2006 08:41 AM
eg64u
Aug 1, 2004 02:44 PM
ANACC2NV
Nov 12, 2001 04:24 PM
