What is the exact difference between h22a4 and h22a1 rods ???
Old Dec 28, 2004 | 03:02 AM
wstef's Avatar
Default What is the exact difference between h22a4 and h22a1 rods ???
The question is not about the crank journal diameters whitch seem to varry between years, but just about putting the type-s pistons.
I did a search, but some people say it is necessary to rebush to acceplt floating piston pin, some others say it is not necessary....
So my question is what is the exact difference between these rods ?
Is the diameter different ??
Is there a lubrification hole on both types of rods ??
Old Dec 28, 2004 | 09:18 AM
wstef's Avatar
Default Re: What is the exact difference between h22a4 and h22a1 rods ??? (wstef)
Really none knows
Old Dec 28, 2004 | 10:52 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wstef &raquo;</TD></TR><TR><TD CLASS="quote">The question is not about the crank journal diameters whitch seem to varry between years, but just about putting the type-s pistons.
... ??</TD></TR></TABLE>
All A1 rods would need to be rebushed for floating. Diameters on both ends are the same.
Old Dec 28, 2004 | 11:02 AM
wstef's Avatar
Default Re: What is the exact difference between h22a4 and h22a1 rods ??? (satan_srv)
Yes, but could you explain me what it exactly means "rebushing" in this case???
If I understand well, the diameter is the same for floating and non-floating pin.
So what is the difference between bushings ???
I would greatly appreciate a precise answer.
Old Dec 28, 2004 | 11:27 AM
satan_srv's Avatar
https://honda-tech.com/zerothread?id=900446
bore out and put in another bushing that will allow the pin to float
Old Dec 28, 2004 | 11:32 AM
wstef's Avatar
So what is the difference between the bushing you bore out and the one you press in if the both diameters are identical ?
Old Dec 28, 2004 | 12:16 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wstef &raquo;</TD></TR><TR><TD CLASS="quote">So what is the difference between the bushing you bore out and the one you press in if the both diameters are identical ?</TD></TR></TABLE>
One is for press fit (no movement), the other is for floating (floats). Likely a oil lubrication hole and a slightly thinner bearing thickness on the floating...just a guess I haven't done it personally I paid a machine shop to do it.
Old Dec 28, 2004 | 11:41 PM
wstef's Avatar
Now I see it much more clearly
- the non floating bushing is pressed by force into rod and does not have possibility to move (turn) into the rod, it is only the piston pin that moves around the pin,
- the pin into a floating one has possibility to turn into rod and into piston.
Modified by wstef at 11:38 AM 12/29/2004
B16FlatBack
Mar 10, 2008 10:27 AM
chilli_822
Apr 22, 2007 05:08 AM
krazydbiker
Mar 24, 2007 02:24 PM
Si Erik
11
Feb 8, 2004 04:50 PM
.ShawnD.
Oct 6, 2003 04:53 PM
