swap ?'s
Old Dec 28, 2004 | 12:10 AM
dochzc's Avatar
Default swap ?'s
i have a 89 crx si and i just got a b18a ls for free and judging if i should put it in which i will be doing my self. my goal is install a b18c gsr and if if i end up installing the b18a ls i will be buying every thing mounts,shift links,axles, ect. my ? is if i buy every thing for the ls out of every thing i buy can i use any of it for the gsr or will i have to buy a whole new set up. is it a waste to buy the set up for the ls if im gonna get a gsr or should i just go for it. thanks for the help
Old Dec 28, 2004 | 03:46 AM
Slopoke's Avatar
Default Re: swap ?'s (dochzc)
Mounts, shiftlinkage, and axles will all be the same between the ls and gsr.
Old Dec 28, 2004 | 02:08 PM
dochzc's Avatar
Default Re: swap ?'s (Slopoke)
do you know if the LS will drop in with no problems or should i expect a little difficulty
Old Dec 28, 2004 | 03:50 PM
Mr_CRX's Avatar
i hate to say it but put a little effort into this by searching. its ALMOST a bolt in affair with the mounts. You will have to bang in the rear crossmember and notch out some room for the alternator. But dude honestly search its been convered a million times.
alvarez.esteban
Aug 27, 2016 12:00 PM
lsturbo*
Aug 22, 2008 08:52 PM
stuie08
Apr 18, 2006 10:00 PM
Bk2fwd
Dec 6, 2004 11:45 PM
es four
Jan 20, 2003 03:31 PM
