about the CAT converter
Old Dec 27, 2004 | 11:53 PM
taffetawhitegsr's Avatar
Default about the CAT converter
so i was putting on my new exhaust today.. or rather just switching out my tanabe for a greddy.. anyways, long story sort, one of the studs on my CAT got fucked up and the bolt wont go in any more.i tried as best i could but i think it just fell off.. my question is.. how bad is this? running the cat to b-pipe with only 2 bolts? TIA
Old Dec 28, 2004 | 12:05 AM
BlackSage's Avatar
Default Re: about the CAT converter (taffetawhitegsr)
Might not be too bad. It shouldnt kill anything. Bolt it up and drive it around the block and let us know what happens
Old Dec 28, 2004 | 12:12 AM
Default Re: about the CAT converter (BlackSage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage &raquo;</TD></TR><TR><TD CLASS="quote">Might not be too bad. It shouldnt kill anything. Bolt it up and drive it around the block and let us know what happens </TD></TR></TABLE>
well the thing is.. ive been drivin it around.. drove about 20 miles with 2 bolts. haha seems to be fine.. makes some funny noises some times.. im guessing its exhaust leak.
Old Dec 28, 2004 | 08:06 AM
BlackSage's Avatar
That sounds about right. Plus there is a gasket that belongs between the cat and the b pipe. When my car didnt have one it would rattle a lot. You might be able to go to a muffler shop and get them to weld a stud back on there.
Old Dec 28, 2004 | 08:27 AM
DontBlink's Avatar
the studs on the cat arent welded in there to begin with. if you want you can take it back off and smack the threaded side of the bolt with a hammer and knock it out and just run a bolt with a nut.
Old Dec 28, 2004 | 10:17 AM
Default Re: about the CAT converter (DontBlink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DontBlink &raquo;</TD></TR><TR><TD CLASS="quote">the studs on the cat arent welded in there to begin with. if you want you can take it back off and smack the threaded side of the bolt with a hammer and knock it out and just run a bolt with a nut.</TD></TR></TABLE>
wow that just saved me from buying a whole new cat which was what i thought i had to do. thank you sir.
Cameron707
May 4, 2017 07:05 PM
H0ndaJunkie
Jul 12, 2005 12:45 PM
fw190bvi
Apr 25, 2005 04:09 PM
TSAngry
Nov 4, 2003 03:30 PM
svw
Sep 25, 2003 09:33 PM
