going to the junk yard
k, If I get a SI transmission from 91, I need matching clutch. Do I need matching Flywheel also? or can I use the DX one that I have? also, Are the splines diffrent on the Axles too??
I'm pretty sure that you will need the flywheel too. Can't remember off the top of my head if there are any differences between the years. I do know that the 88 is different however. Si and DX axles are the same, HF and STD's have smaller splines on the hub side.
got to use 88-91 DX or SI axles...
88 tranny smaller PP smaller flywheel diffrent spline count from 89-91.
89 tranny same PP same flywheel as 88 but same spline count as 90-91.
90-91 bigger PP bigger flywheel same spline count as 89.
so for an 88 you need 88 disk 88 or 89 pp and flywheel or you can upgrade to the 90-91 bigger pp and flywheel but you need the lude disk as posted above.
*89 you need 89 disk, 88 or 89 pp and flywheel or you can upgrade to 90-91 disk and pp and flywheel.
90-91 you use 90-91 disk pp and flywheel or if your in a bind you can use the 89 disk pp and flywheel.
(note: some people have upgraded there disk, pp , and flywheel to the 92-95 civics the flywheel is 2-4 lbs lighter than 89-91 flywheels)
88 is a 21 spline
89+ is a 20 spline
84-87 Prelude 2.0 liter disc is 21 spline, 212mm
88 is a 21 spline
89+ is a 20 spline
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI »</TD></TR><TR><TD CLASS="quote">Thats a little confusing to me. Can you simple that newb terms.</TD></TR></TABLE>
dont get a 88 trany or clutch
explictness
Aug 8, 2005 05:22 AM
LoooseGSR
Nov 12, 2003 11:52 AM
Hybrid CRX
Jul 15, 2002 06:26 PM
