civic with h22 jerking me
Old Dec 27, 2004 | 08:18 PM
angelgsrteg's Avatar
Default civic with h22 jerking me
Recently put a h22 on my civic and everytime that Im driving once the car is at normal temp. the car while on gear it kinda jerks me a couple of times and then the check engine light comes on. Its kinda like if someone was towing me with a rope from the front of the car....Anyways anything helps....Thanks
Old Dec 27, 2004 | 09:38 PM
PrettyLude's Avatar
sounds like your tps is acting up
Old Dec 28, 2004 | 04:13 AM
Monkey Fing a Coconut's Avatar
Default Re: (PrettyLude)
are you going to share with us what the cel code is....???
Old Dec 28, 2004 | 05:26 AM
mgags7's Avatar
definitely get the code, but i would bet your tps is crap....like ^^ said, when the tps goes bad, it will get "dead spots" on it where it will tell the ecu you are giving zero or the last % you were at before it hit the "dead spot" when you actually are giving say 50%.....
if you have these, you need a new tps, but get the code first....
Old Dec 28, 2004 | 05:29 AM
thehondaguru's Avatar
Default Re: (mgags7)
or your motor is knocking like crazy and in limp mode
d601
Jul 29, 2011 05:04 PM
dhn
Nov 5, 2005 02:45 PM
