IS THE LOWER BALL JOINT AND TIE ROD BALL JOINT THE SAME PART #?
they look like they have the same ball joint in there. And on majestic anyone know what section the tie rod is in.
im confused now, how do i replace that ball joint in the tie rod.
you need an outter tie rod end. it is threaded onto the inner tie rod. you loosen up the 17mm or 19mm (i cant remember) jam nut, you separate it from the spindle, count the turns while you rotate it off, reinstall the new tie rod end, and then get an alignment.
http://www.hondaautomotivepart...R+BOX
power steering gearbox.
i think power and manual should be the same.
i did a search for a 93 si, i dont know what you have but look under power
steering gearbox. should be #17
Vagitarian
Feb 20, 2014 05:19 PM
