DYNO TIME, FULLY BUILT LS VTEC, WHAT YOU GUYS THINK******************
I'M TAKING MY CAR TO GET IT DYNO DURING THESE WEEK,WITH A P28 ECU, I WILL BE GOING HONDDATA SOON. WHAT YOU GUYS THINK I WILL DYNO AT...SETUP
*ITR HEADER
*AEBS MANIFOLD
*B18A LS BLOCK FULL BALANCE
*STAGE 2 CLUTCH WITH A 8 POUND FLYWHEEL
*CTR 25 OVER PISTONS ON LS RODS
*FULLY BUILT ALANIZ HEAD, SPRINGS & RETAINERS
*WITH JUN 3 CAMS
*WITH 310 RC INJECTORS
*COMPRESSION FOR EACH CILINDER IS AROUND 275 PSI ALL ACROSS
*ON 100 MIX WITH 91 OCT
Modified by 1320DRAGWORKX at 8:09 PM 12/27/2004
Modified by 1320DRAGWORKX at 8:10 PM 12/27/2004
*ITR HEADER
*AEBS MANIFOLD
*WITH JUN 3 CAMS
ok on a stock p28 No header what intake manifold ? not alot cuz u dont got the frist parts right intake manifold Header and Ecu
if your runing a chipped p28 and jdm type R header you should see 180 to 200hp
I made 196hp on a b20 with 11.5 .20 over je pistons stock b16 head with shunk 2 manifold,skunk 1 cams,jdm dc header,rc 310s and a chipped p28..
SupaFly_Honda
13
Jun 12, 2005 10:39 AM
