running without a crossmember?
Old Dec 27, 2004 | 05:07 PM
JDM_NA_eg6's Avatar
Default running without a crossmember?
I just put on a stainless steel dc 4-1 header on my b18a1 and i need to either notch it or dent the mess out of it. I was wondering if i could drive around without it until i order a traction bar?
Old Dec 27, 2004 | 05:10 PM
eda6's Avatar
Default Re: running without a crossmember? (slowef9)
No. I tried it once. After about 10 ft i said to myself this isn't going to work.
Old Dec 27, 2004 | 05:11 PM
EL Vap133's Avatar
Are you crazy? You can kill yourself without it!
Old Dec 27, 2004 | 05:14 PM
JDM_NA_eg6's Avatar
Default Re: running without a crossmember? (eda6)
thanks. my friends with eg's and ek's said i could but i wanted to double check. would you recommend denting it or notching it with a cut-off wheel?
Old Dec 27, 2004 | 05:15 PM
I8ayellowcrayon's Avatar
Don't even try it. I'd just notch it . A header won't perform like its supposed to if its all bashed up...
Old Dec 27, 2004 | 05:32 PM
HamiltonRex's Avatar
Default Re: (I8ayellowcrayon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote">.
Don't even try it. I'd just notch it . A header won't perform like its supposed to if its all bashed up...</TD></TR></TABLE>
He didnt mean dent the header duh! He ment should he dent the crossmember, or cut the crossmembe with a cutoff wheel.
First cut off the lip, then dent it in.
-Eric
Old Dec 27, 2004 | 05:33 PM
Rostr02's Avatar
Damn I would never even think of doing this
Old Dec 27, 2004 | 05:40 PM
eda6's Avatar
Here's how i did it.
Tools required-oxyacetylene torch, makita grinder, lincoln welding sticks, 1/4" steel
I cut the crossmember so the header cleared. Filled in the gaps with steel. Welded it together, smoothed out the welds with a grinder while checking for cracks. Painted it black afterwards.
Old Dec 27, 2004 | 06:49 PM
heres what i did.
Tools required: Torch, welder, grinder.
I just cut away the lip with the grinder, then i grinded it more.. Then i used the torch heated it up, and used the heat to make it easier to dent (wanted it to be the same sized dent as what the header needed)
Then i welded up the hole along the bottom, many passes with mig welder, grinded it smooth painted it...
I would post pics but we-todd-did dosent seem to be working
Old Dec 27, 2004 | 07:00 PM
JapJunkie's Avatar
Default Re: running without a crossmember? (HamiltonRex)
If this helps, when i tried fitting my aftermarket header on DOHC ZC in my HB it would not go on. I banged the crap out of the x-member and later figured out if i jacked up the motor a lil bit that it would fit perfect, lowered it and didnt even touch the crossmember.
Old Dec 27, 2004 | 07:08 PM
Default Re: running without a crossmember? (JapJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie &raquo;</TD></TR><TR><TD CLASS="quote">If this helps, when i tried fitting my aftermarket header on DOHC ZC in my HB it would not go on. I banged the crap out of the x-member and later figured out if i jacked up the motor a lil bit that it would fit perfect, lowered it and didnt even touch the crossmember.</TD></TR></TABLE>
yes but... this is a different case, its not fitting the header by the crossmember, its once the header is on that the crossmember wont clear and it hits..
But good idea for thouse with 1 piece headers that cant get them past to install.
Old Dec 27, 2004 | 07:11 PM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">yes but... this is a different case, its not fitting the header by the crossmember, its once the header is on that the crossmember wont clear and it hits..
But good idea for thouse with 1 piece headers that cant get them past to install.</TD></TR></TABLE>
Yea i knew that, i was just giving peeps an idea to maybe try this first, and then they would be able to figure out that the x-member needs to be cut
Old Dec 27, 2004 | 07:29 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Yea i knew that, i was just giving peeps an idea to maybe try this first, and then they would be able to figure out that the x-member needs to be cut </TD></TR></TABLE>
cool, waste our time, dick
Old Dec 27, 2004 | 07:37 PM
JapJunkie's Avatar
Default Re: running without a crossmember? (itsallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsallmotor &raquo;</TD></TR><TR><TD CLASS="quote">cool, waste our time, dick </TD></TR></TABLE>
Well hey fuuucker, its good to try that b4 cutting up ****
87crxtype-one
Welding / Fabrication
May 24, 2008 07:05 AM
HXvtec
11
May 11, 2006 12:22 PM
P_t0wn
May 11, 2006 12:11 PM
jdmride
Apr 22, 2006 08:15 AM
db8gsr_teg
Mar 16, 2006 10:05 AM
