4th gen and 5th gen
Old Dec 27, 2004 | 05:05 PM
digitalh3lix's Avatar
Default 4th gen and 5th gen
are the 4th gens H22A1 identical to the 5th gens?
Old Dec 27, 2004 | 05:20 PM
Default Re: 4th gen and 5th gen (Chase)
is one better than the other? even tho its still H22?
Old Dec 27, 2004 | 06:07 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: 4th gen and 5th gen (digitalh3lix)
well the 5th gen is rated at a higher HP
Old Dec 27, 2004 | 06:09 PM
prelude1897's Avatar
Default Re: 4th gen and 5th gen (raylude)
H22A1 is OBD I which handles mods alot better than H22A4 motors which are OBD II
Old Dec 27, 2004 | 06:13 PM
97Preludeguy's Avatar
Default Re: 4th gen and 5th gen (prelude1897)
Aren't the 92-96 H22's also closed deck, as opposed to an open deck from the 97 forward H22's??? Correct me if im wrong...
Old Dec 27, 2004 | 06:45 PM
clemsoncb7's Avatar
Default Re: 4th gen and 5th gen (97Preludeguy)
JDM are closed deck. Which doesn't mean very much. Its supposed to be better for boost but its really the same, no big deal. However, if you wanna boost, h22a1 is better because of obd1. I am in the process of doing so right now
Old Dec 27, 2004 | 09:52 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Preludeguy &raquo;</TD></TR><TR><TD CLASS="quote">Aren't the 92-96 H22's also closed deck, as opposed to an open deck from the 97 forward H22's??? Correct me if im wrong...</TD></TR></TABLE>
that is correct
Old Dec 27, 2004 | 11:33 PM
vtecludeh22's Avatar
Default Re: 4th gen and 5th gen (PrettyLude)
its not 92-96 h22, they started puting the h22 in in 93!
Old Dec 27, 2004 | 11:40 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">H22A1 is OBD I which handles mods alot better than H22A4 motors which are OBD II</TD></TR></TABLE>
96 H22A1 motors are OBDII
Old Dec 27, 2004 | 11:47 PM
@ries's Avatar
Default Re: 4th gen and 5th gen (satan_srv)
4th gen&gt; 5th gen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">its not 92-96 h22, they started puting the h22 in in 93!</TD></TR></TABLE>
this is true for the US but in japan it was 91.5-92... but who cares about japan any how.
Old Dec 28, 2004 | 03:27 AM
Default Re: 4th gen and 5th gen (@ries)
Eh, I was close enough
Old Dec 28, 2004 | 05:46 AM
mgags7's Avatar
Default Re: 4th gen and 5th gen (maxvtec7500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">JDM are closed deck. Which doesn't mean very much. Its supposed to be better for boost but its really the same, no big deal. However, if you wanna boost, h22a1 is better because of obd1. I am in the process of doing so right now </TD></TR></TABLE>
wrong, closed deck helps more than you know.....your lack of intelligence shows through the fact that you think jdm are the only closed deck blocks, and they are not, all of the obdI h22 jdm or us are closed deck......dont assume things....
closed deck holds the sleeves from warping and bowing (at least at the top) on the very WEAK FOR BOOST h22 frm sleeves....so you will need all the help you can get....
Old Dec 28, 2004 | 08:36 AM
satan_srv's Avatar
Default Re: 4th gen and 5th gen (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
closed deck holds the sleeves from warping and bowing (at least at the top) on the very WEAK FOR BOOST h22 frm sleeves....so you will need all the help you can get....</TD></TR></TABLE>
that's a pretty ignorant statement....fact is no matter what deck you have H22a sucks for boost...and it's not because of sleeves, it's because of pistions. While closed deck sleeves or open deck with tabs a la golden eagle that's just good sense, but for average people running N/A motors...it doesn't matter. Hell my fully built H22A4 block was open deck sleeves.
tegsr2o3
Aug 28, 2007 11:57 AM
PreludePhill
Feb 28, 2007 10:25 AM
Thuttle88
Sep 10, 2005 09:41 AM
p3t312
Feb 4, 2005 09:52 AM
KB96VTEC
Sep 22, 2003 11:17 AM
