can i use any TPS or MAP sensor? need fast reply
Old Dec 27, 2004 | 04:24 PM
dropd4door's Avatar
Default can i use any TPS or MAP sensor? need fast reply
i gotta 95 dx with a d16 swap... and im throwin codes for TPS and MAP sensor... i was wondering if any obd-1 map and TPs would work??? i think bseries n dseries tps and maps are enterchangable (sp) anyone give me a 100% answer thanks alot guys
Old Dec 27, 2004 | 07:20 PM
Redline130's Avatar
Default Re: can i use any TPS or MAP sensor? need fast reply (dropd4door)
Yup, D and B series are interchangeable.
Old Dec 27, 2004 | 07:47 PM
TIRENECK's Avatar
Default Re: can i use any TPS or MAP sensor? need fast reply (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Yup, D and B series are interchangeable.</TD></TR></TABLE>
Old Dec 27, 2004 | 08:38 PM
PrettyLude's Avatar
you sure you don't have the plugs in backwards, that is know for happening since they both have the same harness
Old Dec 27, 2004 | 11:07 PM
Redline130's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you sure you don't have the plugs in backwards, that is know for happening since they both have the same harness</TD></TR></TABLE>
Good point
Old Dec 28, 2004 | 03:57 AM
civic-4-ges's Avatar
And not only is it known, it happens very often!
MAP sensor plug is in the same sub-harness as the IAT sensor
TPS is on the same sub-harness as IACV
k624ash
Sep 5, 2008 06:28 AM
dropd4door
Dec 27, 2004 05:13 PM
hatchinprogress
Nov 23, 2004 08:21 PM
Ej1_coupe
Feb 4, 2004 01:46 PM
buck02
Aug 31, 2003 12:51 AM
