can i use any TPS or MAP sensor? need fast reply
Old Dec 27, 2004 | 04:19 PM
dropd4door's Avatar
Default can i use any TPS or MAP sensor? need fast reply
i gotta 95 dx with a d16 swap... and im throwin codes for TPS and MAP sensor... i was wondering if any obd-1 map and TPs would work??? i think bseries n dseries tps and maps are enterchangable (sp) anyone give me a 100% answer thanks alot guys
Old Dec 27, 2004 | 04:25 PM
b16pwrdeg's Avatar
Default Re: can i use any TPS or MAP sensor? need fast reply (dropd4door)
I'm using a D-Series TPS and MAP on my B16A and I'm not having any problems, so I would assume that they are interchangable.
Old Dec 27, 2004 | 04:43 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
i am using d series on my gsr with no probs
Old Dec 27, 2004 | 04:46 PM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropd4door &raquo;</TD></TR><TR><TD CLASS="quote">i gotta 95 dx with a d16 swap... and im throwin codes for TPS and MAP sensor... i was wondering if any obd-1 map and TPs would work??? i think bseries n dseries tps and maps are enterchangable (sp) anyone give me a 100% answer thanks alot guys </TD></TR></TABLE>
maybe you have those sensors plug switched!
Old Dec 27, 2004 | 04:50 PM
dropd4door's Avatar
Default Re: can i use any TPS or MAP sensor? need fast reply (2lua)
i already tried switchin the plugs and resetting the ecu and the codes still show tried the easy stuff first
Old Dec 27, 2004 | 05:05 PM
2lua's Avatar
did you set the tps back to spec? .45 at idle and 4.5 at wot. as for the map sensor if you got one then swap it if not you can try to check it to see if it bad or not.
Old Dec 27, 2004 | 05:07 PM
dropd4door's Avatar
how do you set the sensor?
Old Dec 27, 2004 | 05:13 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropd4door &raquo;</TD></TR><TR><TD CLASS="quote">how do you set the sensor?</TD></TR></TABLE>
-Turn the ignition on
-back probe the middle wire on the tps sensor.
-with the throttle closed it should read .5 volts
-with the throttle completely open, it should read 4.5 volts
If it doesnt, loosen the two screws holding the sensor down, and rotate it till you get the desired readings.
journeyquest
Jul 23, 2014 02:58 AM
darkstormcr
Mar 27, 2011 03:45 PM
ZC-EG-6
Aug 24, 2005 10:45 AM
dropd4door
Dec 28, 2004 03:57 AM
B18C-RnVA
Aug 18, 2002 03:01 PM
