90-91 and 92-93 front lip
is there a difference between the 90-91 and the 92-93 integra front lip? I want to get a carbon fiber lip for my 91 teg, but can't find one. aren't all g2 integra bumpers the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bootleg R »</TD></TR><TR><TD CLASS="quote">no....90-91 bumper is different from 92-93.</TD></TR></TABLE>
Yep. Most people opt for the 92-93 bumpers for the nicer shape, but the 90-91's look sexy with that front lip mentioned below:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">jdp makes a hot cf lip for the 90-91 check em out
http://www.jdpengineering.com</TD></TR></TABLE>
Then again w/out sideskirts your car will be like below:
--()--()_ vs. \__()__()_
I've always argued to try and keep it all the same so you don't have your "jaw" hanging over, but it really depends on preference. I will try and see if I can find some different pictures of the bumpers as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout289 »</TD></TR><TR><TD CLASS="quote">they are definately different, but are they interchangeable?</TD></TR></TABLE>
Yes, but I'm not sure how much work is involved. Have you checked http://www.g2ic.com? If I have some free time I will take a look under their teg tips, but I'm sure there has to be a DIY somewhere on this. I know people commonly change them out though for the 92-93 look. I was considering the same thing because my car was wrecked on the side so I might buy a 90-91 and put my bumpers on there.
Edit: Found it! good 'ol g2ic...
http://www.g2ic.com/tegtips/exterior/13.html
It actually doesn't sound too tough either. If I ever do this I will be sure to take pictures as well, and maybe see what I can clean/inspect w/ the front bumper off.
yeah...I don't care to swap to a 90-91 bumper, but I asked cuz it seemed like a lot of people would prefer the 92-93 bumper. it's more pretty.
they are not interchangable to an exstent, you need to rebar and the brackets that bolt to the radiator support off the yr your going to use the bumper for.
90-91 bumpers dont work w/92-93 brackets
thats from experience
90-91 car
to fit 92-93 bumper
CUT/SHAPE FOAM to fit new bumper
OR go no foam
IF YOU USE 90-91 Support you MUST use 90-91 brackets
if you use 92-92 support you MUST use 92-93 brackets
YOU CANT use 92-93 support+90-91 brackets or vise versa
Follow this post and it will fit
to fit 92-93 bumper
OR go no foam
