FS B series COMPLETE t2t04e turbo kit (EVERYTHING INCLUDED TO BOLT RIGHT ON!!!)
Old Dec 27, 2004 | 01:11 PM
g0ldywang's Avatar
Default FS B series COMPLETE t2t04e turbo kit (EVERYTHING INCLUDED TO BOLT RIGHT ON!!!)
Everything comes with this kit!
Drag gen3 manifold
Turbonetics t3t04e turbo .60 (only 300 mi on turbo, almost completely brand new, NO SHAFT PLAY)
Tial 38 mm wg
Custom 2.25 ic piping (still just mild steel so could paint, coat, polish, etc)
custom 18x8x3 fmic
custom 2.5 in dp welded directly to 2.5 in flex test pipe (will bolt right to cat back)
TurboXS RFL BOV
TurboXS single stage boost controller
GReddy Turbo timer
Autometer Boost gauge
DSM 450 cc injectors (blue tops) w/resistor box
GReddy emanage w/optional injector and ignition control harnesses
Comes with PC Emanage support tool and will include laptop to tune if needed (makes complete ignition and injection maps, masks boost to ecu so missing link is not needed, works like a standalone with the additional harnesses and support tool)
oil pan pre-tapped with hard oil line welded on for best flow (would like a stock one back if possible but not necessary)
Comes will all hardware, gaskets, clamps, silicone pipe connectors, oil lines, absolutely everything you need to bolt on and run safely, you don't even need to tap your oil pan, you can bolt this kit all right on! Asking 2600 o.b.o for everything. Pics will be up tonight. PM or email goldywang@yahoo.com.
***Also i have a thermal 3 inch polished catback exhaust that i am looking to get rid of but would really like to trade for a 2.25 na exhaust. Exhaust only 6 mos old.
Thanks!****
Old Dec 28, 2004 | 08:00 AM
Tundatoe's Avatar
Default Re: FS B series COMPLETE t2t04e turbo kit (b16agreddynx)
any pics
94c1v1cex
Jun 2, 2008 08:41 AM
xCIVICx
Jan 12, 2006 05:01 AM
g0ldywang
Dec 28, 2004 04:21 PM
98Spec EK
Jun 18, 2004 04:29 PM
arsenaldragster
Sep 20, 2003 01:08 PM
