5th gear popping out on it's own
Old Dec 27, 2004 | 11:25 AM
Riceburner247's Avatar
Default 5th gear popping out on it's own
I just made a 500 mile road trip for the holidays and the HB did better than it ever had before. Exept for the fact that the tranny decided that it didn't like 5th gear. Twice.
91 HB DX with 125,xxx miles, manual. I'm cruising around 75 mph and out of nowhere the gearshift literally pops out of 5th and into neutral and my rpms skyrocket because of my foot on the gas. Not to mention that when this happens it scares the living **** out of me for a second. I just push the clutch in and put it back in 5th and all is well for the next 150 miles.
Same happens about 200 miles later. I just put it back in 5th and all is well. It just started doing this and I have no idea what is causing it.
Anybody encounter this before or know what's going on?
Old Dec 27, 2004 | 11:50 AM
efhatchster's Avatar
Default Re: 5th gear popping out on it's own (riceburner247)
well it looks here too me that you syncros are gone or try too put some syncromesh gear oil in transmission it helps
Old Dec 27, 2004 | 01:27 PM
tRex99's Avatar
Default Re: 5th gear popping out on it's own (efhatchster)
yup my buddies teg did this all the time. first gear was a pain in the *** to get into and 5th would pop out. Syncros are jacked. He did add LUCAS to it and it worked for the 5th gear prob but the 1st gear didnt help much it was to messed up..
Old Dec 27, 2004 | 01:50 PM
Default Re: 5th gear popping out on it's own (tRex99)
The rest of the gears are no problem, no slipping or grinding. I've heard good stuff about Syncromesh so I think I'll try that.
Thanks for the replies guys.
Old Dec 27, 2004 | 02:25 PM
bloopie's Avatar
Sounds more like a shift fork problem.
My tranny blew up about 100 miles after this started occuring in my tranny...
Be careful.
Old Dec 27, 2004 | 03:15 PM
Default Re: 5th gear popping out on it's own (tuner.fish)
Care to explain?
My tranny sounds fine, it doesn't grind or make any wierd noise for that matter. Shifts into all gears with ease, I kinda doubt it's gonna blow.
Old Dec 27, 2004 | 03:26 PM
Burlyirishdude's Avatar
no....Put more fulid in your tranny....i learned that one the hardway....Go and add about 2 quarts.....that should help....it helped me out so much....
Old Dec 27, 2004 | 03:53 PM
Default Re: 5th gear popping out on it's own (Burlyirishdude)
lol, ya know, I changed my axles last month and I think a little tranny fluid came out. Just been too lazy to do a complete change.
I thought that might have been the problem, but I couldn't figure out how.
Old Dec 27, 2004 | 04:16 PM
jdm Ef-9's Avatar
your synrossss are bad....would just be easy to get a new trans....sence your there,might as well upgrade your clutch>
Old Dec 27, 2004 | 04:22 PM
Fred n J_v2.0's Avatar
had this happen on my old car... axle seal was bad, resulting in low trans fluid...
just refill and it should go away...
everyone was tellin me that same thing about the synchros being busted... turns out that adding some trans fluid helped the car stay in 5th
I8ayellowcrayon's Avatar
Its not the synchro thats bad. Its the snap ring. This is what provides the "click" when you go in gear, and keeps the fork where its supposed to be. This is usually caused by low fluid levels. My 5th gear snap ring actually broke and locked my tranny up....
BTW, 1.9 quarts of oil is all the tranny is supposed to take. I wouldn't put any more in there. I don't know much about different brands of fluid to help, but if putting the right amount of oil (10W-30) doesn't help, ask around .
Old Dec 27, 2004 | 07:04 PM
erebunicrx's Avatar
had this happen to my tranny and a friends, it was low on oil (the tranny)
Old Dec 27, 2004 | 08:43 PM
90LSpimpin's Avatar
Default Re: (erebunicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx &raquo;</TD></TR><TR><TD CLASS="quote">had this happen to my tranny and a friends, it was low on oil (the tranny)</TD></TR></TABLE>
Old Dec 28, 2004 | 09:32 PM
philly-O's Avatar
Default Re: (89SiPimpin)
mine pops out of gear every time i let off the gas, it also makes a scratching noise too.
Old Dec 28, 2004 | 11:15 PM
kc90hb's Avatar
Default mmm
yea my tranny grinds when i "try" to put it into reverse and is a bitch to get it into 1st sometimes, i need a flush
bigmaccrew
May 16, 2014 12:05 PM
brlabrune
Feb 23, 2009 12:37 PM
92eg6lsvtec
Jul 9, 2008 07:08 PM
MTR.18
Mar 27, 2005 08:11 AM
