Servicing my automatic tranny
Im kind of a newbie at servicing hondas. I have a 94 accord lx f22b2 motor with a automatic trans. How do you change the atf fluid in the car? Since i don't see a pan, do you almost treat the change like an oil change?
Here is a complete write-up that was provided by cmrvi1:
(Okay cmrvi1 ?) Okay:
Honda Auto Trans Flush 1 case (12 qrts) Honda ATF ($50.) 1 new drain bolt washer $1.
1) Put the front of the car up on jackstands with the wheels off the ground. Put a large container under drain plug.
2) Remove the transmission drain plug (3/8" drive ratchet works fine). Let transmission drain and wipe sludge off drain plug.
3) Reinstall drain plug and snug (not tighten). Fill transmission with three quarts of ATF.
4) Start engine and shift into drive. Gently accelerate and let transmission upshift through the gears (don't go over 50 MPH).
5) Step on brakes and bring speedo to 0.
6) Shift into reverse and accelerate to 20 MPH.
7) Bring speedo back to 0 with brakes. Shift to park and shut off engine.
8) Repeat steps 2 through 7 TWO MORE TIMES.
9) Drain the transmission once more. Reinstall drain plug and tighten firmly (don't forget to reinstall crush washer).
10) Remove jackstands and put vehicle on level ground.
11) Fill transmission with 2 1/2 quarts of ATF. Start engine. Shift to drive, then reverse, then put back in park and shut off engine.
12) Check transmission fluid level. Top off if needed to bring fluid level to the top of the crosshatch marks on the dipstick.
allm0torGSR
Aug 22, 2004 08:53 PM
