How high of compression can I go with a Gsr motor?
Old Dec 27, 2004 | 10:28 AM
Collateral's Avatar
B A N N E D
Default How high of compression can I go with a Gsr motor?
Sorry for the n00b question, however..just wondering..would I be safe to run US or jDM itr pistons in a gsr motor? And still be able to run pump fuel?
I know cause of the chambers in the head are different on gsr's..cause compression to be much higher.
Whats the highest I can go for street driving?
Alaniz is doing my head currently, which consists of
Skunk 2 Stage 2 cams
Skunk 2 Cam gears
Bowl Porting
Street master valve job
Skunk 2 Manifold
Skunk 2 Valve Springs and Valves
What do you recommend doing to my block to 200+WHP with this head setup?
Im also gonna be running Hondata S200
Thanks for ANY help you can provide...its much appreciated
Old Dec 27, 2004 | 11:23 AM
DEVIOUS_EG*'s Avatar
Default Re: How high of compression can I go with a Gsr motor? (collateral)
JDM itr or the p30's will do fine in a daily driver gsr motor.. you can still run on pump 91..
Old Mar 25, 2005 | 05:41 PM
baby91hatch's Avatar
dude run p30 piston's or b16a2 pistons or ctr pistons the gsr has a welded valve chamber head so it will make awesome compression
Old Mar 25, 2005 | 05:54 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (baby91hatch)
yea it's safe... im goin to be running ctr pistons in my ls with 93 octane.. so thats around 13.1:1compresion with a gsr head
Old Mar 25, 2005 | 06:08 PM
hondaeg8's Avatar
Default Re: How high of compression can I go with a Gsr motor? (Collateral)
i will be running b16 pistons in my motor that is currently getting worked on.
Old Mar 25, 2005 | 07:00 PM
icon_race_eg's Avatar
Default Re: (turbofienD 04)
i did a compressio test on my setup and i came up with 11.588:1
i got gsr head on ls block with pr3 pistons... good comp ratio for street
but dont know where u got 13:1 i may be wrong though
Old Mar 25, 2005 | 09:56 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: (mac13_34)
He was talking about B16B/CTR/PCT pistons.
enokcrx
23
Jul 9, 2013 07:04 AM
LvN
Sep 20, 2006 01:43 PM
j spec
11
Jul 26, 2006 01:36 PM
GSRCRXsi
15
Dec 1, 2005 11:50 AM
flashgsr
Sep 15, 2002 08:42 AM
