Car wont start HELP ASAP
Old Dec 27, 2004 | 10:20 AM
nxstrikerxn's Avatar
Default Car wont start HELP ASAP
my car wont start. the reason y iono it start b4 but the battery kept on being drain so then i try to locate the problem by tracing a wire n i found that i have a bunch of relays n mickey mouse wires under my dash. I try to take out one relay cuz i have a feeling it was a engine kill but somehow i pull it n it didnt work the car wont start. the only noise i can here is click click wen i try to start it so i was wondering does ani of guys on HT that live in OC can help me out thnx alot i really need to get my car working for skool 714 553 3183
Old Dec 27, 2004 | 10:22 AM
endlesswinterco's Avatar
Default Re: Car wont start HELP ASAP (nxstrikerxn)
battery dead, try to jump. if it dosn't start then, prob alternator
Old Dec 27, 2004 | 10:23 AM
snatch's Avatar
Paragraphs are you're friend, so are words instead of abbreviations...
Did you do something and then the car wouldn't start?
Check for fuel and spark too.
edit: check battery too like ridnlowhatch said
Old Dec 27, 2004 | 11:25 AM
hott95eg's Avatar
Default Re: Car wont start HELP ASAP (******)
Yes, and even if the alternator is screwed the engine should still run off the battery for a few moments--Is the click coming from the starter? If so you know the starter solenoid is working, but it wont turn? Be more specific please. Umm get out a DVOM and test light to do a parasitic drain test, no more thasn 5mA
Old Dec 27, 2004 | 12:13 PM
IVI's Avatar
IVI
Default Re: Car wont start HELP ASAP (hott95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95eg &raquo;</TD></TR><TR><TD CLASS="quote">Yes, and even if the alternator is screwed the engine should still run off the battery for a few moments--Is the click coming from the starter? If so you know the starter solenoid is working, but it wont turn? Be more specific please. Umm get out a DVOM and test light to do a parasitic drain test, no more thasn 5mA</TD></TR></TABLE>
not if the battery is dead.
what you should do is attempt to jump it, then remove the cable, if it dies then your alternator is not giving power.
why dont you also plug the relay you pulled out back in since you have no idea what its for right now.
sixfourkiller
Jun 17, 2009 10:05 AM
cilvia
Dec 30, 2006 10:49 AM
KloC 95 EG
Dec 9, 2005 02:16 AM
posterchild
Jun 26, 2004 02:09 PM
[626]95-GSR
14
Feb 27, 2003 07:45 AM
