Gas mileage down from 350+ to 200 Miles on a tank....WTF
My 89 Si Hatch with a D16y8 swap and bolt ons went from a steady 350 miles on a tank to all of a sudden 200/225 miles on a full tank.
WTF
Nothing changed except for a Dyno Tune on a Apexi AFC....and all the adjustments on the tune were to LEAN out the motor. So fuel economy should have gotten better, not worse.
I am so damn confused.
Ideas?
WTF
Ideas?
don't know if this applies to your situation, but i run thick motor oil and when the temps drop the 50W contributes to lesser fuel economy.
I'm running 10w-30 have been all season.
Does that matter?
Another question.
The injector resistor box has nothing to do with this correct? If the box is either...Working....or NOT working. There is no inbetween? or am I wrong in this matter?
Does that matter?
Another question.
well every morning I warm up my car for a good 10 mins and I see about a 50-75 mpg decrease per tank......have you been warming up your car lately?
No, I dont warm up, but now that you metion this.
My car has been not able to idle at all when I first start it, untill it is up to temp. It just falls to like 200 RPM then dies out.
My mileage always dropped like a stone when it got cold - like below 32 - outside. I think the fuel has a harder time vaporizing at the lower temps, so it's not running as efficiently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by groundedcivic91 »</TD></TR><TR><TD CLASS="quote">No, I dont warm up, but now that you metion this.
Bad CTS, maybe?
Bad CTS, maybe?
check for vaccum leaks my buddy had a bad one on his car and was only getting like 150 miles to a tank.
check your fuel filter to see if there's any leakage or cracks, also check your fuel line that goes into the fuel regulator if u have one, if not check the fuel vaccum hose that's connected near the brake booster hose. Could be a leakage.!!
aziatekverse
Honda Civic (2006 - 2015)
25
Aug 11, 2008 08:41 PM
daonei
Nov 19, 2007 04:18 PM
CrOmEdOmEcHaMbEr
18
Dec 26, 2002 07:56 PM
