Will a 90-91 clutch fit on my 89 crx?
Old Dec 27, 2004 | 10:16 AM
alpalwal's Avatar
Default Will a 90-91 clutch fit on my 89 crx?
I am in need for a new clutch for my 89 crx. I was looking on ebay and they only had clutches for 90-91 or 88 and lower crx. (besides the stock ones for the 89). I'm looking to get about a stage 3 clutch for my d15. Will the 90-91 clutches fit?
Thanks
Old Dec 27, 2004 | 10:19 AM
hahagasdcrx's Avatar
Default Re: Will a 90-91 clutch fit on my 89 crx? (alpalwal)
You will need the flywheel from a 90-00 civic sohc.
Someone correct me if im wrong but the 89-00 tranny has the same spline count but uses a smaller clutch disk, therefore you needing to swap to a 90-00 flywheel to bolt the clutch to.
From crxsi.com,
» 88 has a 21 spline input shaft, the 89-91's have a 20 spline shaft.
» 90-91 clutch is 212mm, the 89 is 200mm and the 88 has either a 200 or 190mm.
Old Dec 27, 2004 | 10:22 AM
saltyblue's Avatar
sounds right to me.
Old Dec 27, 2004 | 10:35 AM
sohc hatch's Avatar
Default Re: (saltyblue)
alpalwal's Avatar
Alright, one last question, do you only have to drop the tranny to prelace the flywheel or do you have to take out the engine?
Old Dec 27, 2004 | 10:38 AM
saltyblue's Avatar
drop the tranny.
Old Dec 27, 2004 | 12:44 PM
alpalwal's Avatar
One last thing. Can someone positively confirm that a 90-91 clutch/flywheel will fit in my 89 crx even though the 90-91 is 12mm bigger? I really want to be sure about this.
Thanks
Old Dec 27, 2004 | 02:59 PM
yes the flywheel will bolt up . Its the clutch disk that is 212mm in size. The flwheel will bolt onto your motor and you will just need the right clutch disk for your year tranny.
Old Dec 27, 2004 | 06:20 PM
PhatwhipsJDMkits's Avatar
Default Re: Will a 90-91 clutch fit on my 89 crx? (hahagasdcrx)
The clutch disc will fit, it has the same spline count 89 90 91 etc. You will need to get a 90 up flywheel because the clutch disc is bigger than the 89 flywheel. And as far as a stage 3 clutch goes with your d15 i dont know what your running but stage three may be pretty harsh. I have an Exedy stage one and act streetlight flywheel and it grips really well. With such a light car and only a d15 i think stage one or maybe stage two would be enough.
Old Dec 27, 2004 | 06:40 PM
alpalwal's Avatar
So, the flywheel works, but I need a 89 clutch, not a 90-91?
Old Dec 28, 2004 | 06:13 PM
Get the same year clutch as flywheel 89-91 will all spline up.
janz3n
Apr 14, 2007 06:06 PM
shadycrx
Jan 2, 2006 10:08 PM
dstudent
Nov 2, 2004 09:06 AM
sykohatch
Aug 16, 2004 08:51 PM
mugensport9
10
Sep 23, 2003 09:01 PM
