When the car is running which side of the timing belt should have slack?
Old Dec 27, 2004 | 08:08 AM
SuicideSlide's Avatar
Default When the car is running which side of the timing belt should have slack?
When the car is running which side of the timing belt should have slack? Just curious if my timing belt is tensioned wrong or not. Or I may have stretched it.
Old Dec 27, 2004 | 08:56 AM
JDMlyfestyle's Avatar
iF you are facing the cam gears
the left side should have the slack
Old Dec 27, 2004 | 01:30 PM
Default Re: (JDMlyfestyle)
Is there a way I can tighten the slack up or properly tension the belt without removing everything again.
Old Dec 27, 2004 | 01:39 PM
u have to take the belt off again and play with it .
I use the old bicylcle trick own how u put ur chain back on.
First loosen the tensioner I take it and be sure thats it TDC. and give it a turn so the cams rotate counter clockwise. a inch or inch and a half. and then put the belt back on and rotate the cams back to TDC where the lines meet up. then tighten the tensioner. that always works for me
Old Dec 30, 2004 | 03:03 PM
Vega Racer's Avatar
Default Re: (TurbLu)
its real easy if you just use a pry bar and a screw driver.
dleccord
Apr 13, 2020 08:03 AM
airikkCRX
Apr 2, 2010 08:29 AM
420aNT
May 5, 2003 08:08 AM
Shark Tank
Oct 18, 2002 12:08 PM
Comptech98GSR
Oct 30, 2001 08:06 PM
