B20VTEC vs. LSVTEC...which is the better and faster setup?
Old Dec 27, 2004 | 07:49 AM
Rice Is Best's Avatar
Default B20VTEC vs. LSVTEC...which is the better and faster setup?
https://honda-tech.com/zerothread?id=962406
i just read that thread about what a lsvtec can do to a stripped hatch.
my question is would a built b20tec (85mm sleeved b18 (2L), type r head, _______ camshafts, _______ valves and springs, type r crank and rods, type r 4.7 tranny, 11.__:1 compression pistons, ported 65mm type r intake manifold and throttle body.
would this setup be better and faster than the setup in the above thread of the lsvtec? im building a b20vtec but when i saw that thread it made me think.
leme know guys
Old Dec 27, 2004 | 01:34 PM
GOLDBERG's Avatar
Default Re: B20VTEC vs. LSVTEC...which is the better and faster setup? (KockAsian)
ummm the b20 has more displacement...more power...faster....... make sure u resleeve tho for 85mm
Old Dec 27, 2004 | 01:55 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: B20VTEC vs. LSVTEC...which is the better and faster setup? (GOLDBERG)
No replacement for displacement.
Old Dec 27, 2004 | 02:14 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">ummm the b20 has more displacement...more power...faster....... make sure u resleeve tho for 85mm</TD></TR></TABLE>
That doesn't make a whole heck of a lot of sense.
If you recommend sleeving the block then what is the difference between which one he should get (acutally in this case the LS would be easier to sleeve right)? Sleeved to 85mm and the cranks are the same so you are basically contradicting yourself. At least the way you have it worded is as such.
2 blocks, same stroke, same bore (sinse you recomend sleeving it), but one has more displacement and is faster?
Maybe just a case of the Monday's.
Old Dec 27, 2004 | 03:14 PM
kaptr1d's Avatar
Default Re: B20VTEC vs. LSVTEC...which is the better and faster setup? (EKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">That doesn't make a whole heck of a lot of sense.
Maybe just a case of the Monday's. </TD></TR></TABLE>
nope, ur rite. if ur gonna sleeve the block then theyre the same motor...
Old Dec 27, 2004 | 03:25 PM
DIFFUT'S INC.'s Avatar
Default Re: B20VTEC vs. LSVTEC...which is the better and faster setup? (kaptr1d)
B20/VTEC
EKdriverin703
11
Mar 10, 2011 01:21 PM
smutmonger
Jan 31, 2007 04:30 AM
gsxryder415
Jun 14, 2006 09:35 AM
elegiono
Feb 19, 2005 02:09 PM
Rice Is Best
Dec 27, 2004 09:36 AM
