Teg GSR with Skunk2 IM, TB 65mm will AEM v2 from GSR will fit
Old Dec 27, 2004 | 06:20 AM
djphoebus's Avatar
Default Teg GSR with Skunk2 IM, TB 65mm will AEM v2 from GSR will fit
I have a quick queston, I have an integra GSR 97 and want to get a Skunk2 intake manifold with a JG Throttle body woch is 65mm. Now, alot of people says that when you change the stock IM for a GSR Skunk2 IM you need to have a Type R intake? Can you told me if i can make fit a GSR V2 and why it wont fit? if not what's the difference between a GSR skunk2 manifold an a Type R Skunk2 intake MAnifold?
Thanks,
Old Dec 27, 2004 | 06:28 AM
Dan GSR's Avatar
Default Re: Teg GSR with Skunk2 IM, TB 65mm will AEM v2 from GSR will fit (djphoebus)
the gsr intake won't fit due to the position of the throttle body compared to the skunk2 manifold
Old Dec 27, 2004 | 06:53 AM
Dee's Avatar
Dee
Default Re: Teg GSR with Skunk2 IM, TB 65mm will AEM v2 from GSR will fit (Dan GSR)
The GSR SK2 is essentially an ITR intake mani with larger runners and a GSR head flange. The Sk2 mani sits the TB a couple inches higher so hacking and wacking will be needed to make a GSR intake fit.
Old Dec 27, 2004 | 07:59 AM
3.504's Avatar
Default Re: Teg GSR with Skunk2 IM, TB 65mm will AEM v2 from GSR will fit (Dee)
use the ITR intake if you dont already own the part, if you do own the part, hack it up
Old Dec 28, 2004 | 05:42 AM
djphoebus's Avatar
Default Re: Teg GSR with Skunk2 IM, TB 65mm will AEM v2 from GSR will fit (3.504)
Thanks for the details
Old Dec 28, 2004 | 08:17 AM
1whitedc2's Avatar
if you get the sk2 IM, unless you have upgraded your cams, don't go for larger JG TB, it doesn't help, you would lose flow velocity, i would upgrade to something at least ITR intake cam...
Old Dec 28, 2004 | 09:42 AM
djphoebus's Avatar
Default Re: Teg GSR with Skunk2 IM, TB 65mm will AEM v2 from GSR will fit (1whitedc2)
I'm buying all my parts and will build the motor in february...Skunk2 stage 2 are on the way..
hondamama7894
Oct 27, 2006 07:33 AM
91crx but i heard vtec
Oct 9, 2005 12:48 PM
IggyBcool
Apr 30, 2005 07:14 PM
ownedbyvtec
Jan 13, 2004 02:39 PM
