97 gsr, 70mph cruise control Q?
Guest
Posts: n/a
driving down the freeway with the cruise contol on doing 70mph, interior light shut off, rpm's go to 0, mph goes to 0, car still running normal, so we pulled over, then car started back up fine.
What could this be? a short in the cruise control?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 »</TD></TR><TR><TD CLASS="quote">driving down the freeway with the cruise contol on doing 70mph, interior light shut off, rpm's go to 0, mph goes to 0, car still running normal, so we pulled over, then car started back up fine.
What could this be? a short in the cruise control?</TD></TR></TABLE>
Im not sure what you are saying happened
You were driving and your interior lights shut off and the gauges stopped working? Then I am guessing you pulled over, shut off the engine, started it back up and everything was normal?
You might want to check the thing and the other thing.....see if that helps
But seriously...yeah...what interior lights are you talking about?
Did the car die when it happened or did you pull over and shut it off?
If you ask a better question, you might get a better answer.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage »</TD></TR><TR><TD CLASS="quote">Im not sure what you are saying happened
You were driving and your interior lights shut off and the gauges stopped working? Then I am guessing you pulled over, shut off the engine, started it back up and everything was normal?</TD></TR></TABLE>
Exaclty
Exaclty
