Z6 swap- rpm switch activated vtec??!!?? --(searched)
Old Dec 26, 2004 | 10:31 PM
kenjief8's Avatar
Default Z6 swap- rpm switch activated vtec??!!?? --(searched)
well i am swapping in a d16z6, and on my last crx the guy had a d15 vtec wired w/ a rpm switch. I would like to go this route again. anyone ever do this or have a wiring diagram of how to?? thanx
Old Dec 26, 2004 | 10:48 PM
RC_SKUBY's Avatar
Default Re: Z6 swap- rpm switch activated vtec??!!?? --(searched) (kenjief8)
My advice to you is spend the extra money and buy a obd-0 b16 ecu, so vtec engages at the point its supposed to when its supposed to. vtec is a little more complicated then imagined it kicks in at a certain oil preasure for a point. but who am i kidding ive ran vtec on a switch before also but its alot more fun imo to be able to cruise around and not have to worry about flippin the switch and just having it kick on on its own.
Old Dec 26, 2004 | 10:56 PM
kenjief8's Avatar
Default Re: Z6 swap- rpm switch activated vtec??!!?? --(searched) (skuby_do)
what i am talking about kicks in on its own, it is a rpm switch w/ replacable chips for different rpm activations. so i plug in a 4600 rpm chip vtec automatically kicks in at 4600. but thanx for the quick reply.
Old Dec 26, 2004 | 11:07 PM
RC_SKUBY's Avatar
whats the name of the device that you purchased? you should just have to run the vtec wires from the solenoid into there and then a wire from the green wire in the distributor to trigger the activation point like a tach, not sure if this helped you out btw im a little drunk so im doing the best i can.
Old Dec 26, 2004 | 11:09 PM
kenjief8's Avatar
well i haven't bought it yet, i am going to, it is msd part #8950
and i was looking fo that kind of answer, thanx
but i would still like to know if anyone here has ever done it. and some type of wiring diagram, hell the motor isn't even in my car yet.
Old Dec 26, 2004 | 11:19 PM
RC_SKUBY's Avatar
alright, i had the wiring diagram laying in my room but i must of threw it a way. good luck though.
Old Dec 27, 2004 | 05:54 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenjief8 &raquo;</TD></TR><TR><TD CLASS="quote">well i haven't bought it yet, i am going to, it is msd part #8950
but i would still like to know if anyone here has ever done it. and some type of wiring diagram, hell the motor isn't even in my car yet. </TD></TR></TABLE>
http://www.msdignition.com/pdf/pn8950.pdf
Old Dec 27, 2004 | 06:10 AM
QUiKSR20's Avatar
Default Re: Z6 swap- rpm switch activated vtec??!!?? --(searched) (jlicrx)
Why not just do it the right way. OBD1 Conversion harness for under $100 then just use an OBD1 Dizzy + O2 sensor and run a P28 Your car will run way better and perform better as well.
Old Dec 27, 2004 | 06:37 AM
tgreaves's Avatar
You just need to send 12 volts to the vtec noid.. You can get a rpm switch from summit racing.. Get either a msd one or summits own brand of one.. If you get summits brand you need to set it at 1/2 the rpms you want it to engauge at since its meant for v8's..
Old Dec 27, 2004 | 06:58 AM
kenjief8's Avatar
Default Re: Z6 swap- rpm switch activated vtec??!!?? --(searched) (tgreaves)
/\/\ thats the answer i was looking for thanx man.
Shoot5Hole84
Apr 17, 2010 10:20 PM
philkehn
10
Oct 3, 2006 11:55 AM
greddy13
May 16, 2006 06:48 PM
green91
17
Dec 29, 2004 03:27 PM
