Removing Steering wheel from 91 Si
Old Jan 6, 2002 | 03:36 PM
Todd00's Avatar
I said I don't want a title!
Default Removing Steering wheel from 91 Si
How do I remove the wheel from a 91 Civic Si? I'm putting a momo on it.
Thanks.
Old Jan 6, 2002 | 03:42 PM
therealciviczc's Avatar
Default Re: Removing Steering wheel from 91 Si (Todd00)
POP the center out. Use a 19mm on the center hub bolt, and you're done. Be sure to keep the wheels straight when you do this that way you put the momo on straight.
If it isn't a 19, its a 17mm. I haven't done it in a little while. Also, obviously you'll have moved the wheel by breaking the bolt loose. Be sure to put it back to straight before you remove the steering wheel.
Old Jan 6, 2002 | 03:44 PM
Todd00's Avatar
Default Re: Removing Steering wheel from 91 Si (therealciviczc)
Does the center "H" pop out on a Civic Si? I figured that I'd have to take the entire horn cover off.
Old Jan 6, 2002 | 04:07 PM
Mugen Dom's Avatar
yes take a small flathead screw driver and pry it off it will come out and ull see the bolt
Old Jan 6, 2002 | 05:19 PM
rpr's Avatar
rpr
Default Re: Removing Steering wheel from 91 Si (jdmB18hatch)
Not to get nit-picky, but it's a nut, not a bolt, and a bit of advice, loosen the nut off all the way, then spin it back on a couple turns before you pull the wheel off. If the wheel sticks, and then pops off...
And trust me, you will get the wheel on off-center the first time you do it, so be prepared to pull it off again
[Modified by rpr, 9:21 PM 1/6/2002]
Old Jan 6, 2002 | 06:04 PM
brad.'s Avatar
Default Re: Removing Steering wheel from 91 Si (rpr)
nut......bolt.......either one, but both of them get screwed
Old Jan 6, 2002 | 06:10 PM
brad.'s Avatar
Default Re: Removing Steering wheel from 91 Si ([626]JDM-b16a-EF9)
had to take my stocker out for this one...
need a JDM cluster to replace the previous owners ricer antics
[Modified by [626]JDM-b16a-EF9, 7:13 PM 1/6/2002]
Old Jan 6, 2002 | 06:28 PM
BoostedED9's Avatar
that is one bad *** steering wheel... i likes alot....
Old Jan 6, 2002 | 07:38 PM
Todd00's Avatar
Default Re: Removing Steering wheel from 91 Si (ED9Hybrid)
Ok, got off the stocker and put my Momo on Appreciate the help.
Old Jan 7, 2002 | 01:45 AM
brad.'s Avatar
hey thanks ED9!
and good job Todd
Old Jan 7, 2002 | 04:21 AM
TypeR0207's Avatar
I need to go take pics of my 230mm Momo ....... be right back!!
Old Jan 7, 2002 | 06:11 AM
TypeR0207's Avatar
Default Re: Removing Steering wheel from 91 Si (TypeR0207)
Here's a link to mine:
http://www.clubphoto.com/reward.php?...ick377557&pwd=
Its a ten minute job ........
Old Jan 7, 2002 | 07:43 AM
Todd00's Avatar
Yeah, MUCH easier than replacing the wheel on my ITR. The horn even was easy on the EF.
While I was at it, I put a 99-00 Civic oem CD player in the dash too. That was a piece of cake as well.
Old Jan 7, 2002 | 08:08 AM
brad.'s Avatar
Top Power
Old Jan 7, 2002 | 08:24 AM
Mugen Dom's Avatar
how well did the 99 si raio go in wut did u use to wire it in u use the factory harness and splice it in? i have one but no harness do u know wut else fits the harness like wut other cars
Old Jan 7, 2002 | 08:30 AM
SiR Kid's Avatar
New User
Todd00, What all did it take to put in the 00 Si Cd player.. I'd like one in my car so If it gets stolen, I'm not so pissed!
TypeR0207 WOW, that Momo shift **** looks nice n HUGE on the end of the STD's pole of a shifter My buddy's got the same only a smoked color on his Black (9 GSR... it's pretty sweet, but carries alot of heat/cold with it whenever you use it... COLD when it's cold outside and HOT AS HELL when it's hot out, which is exactly why I got rid of my CTR shift ****... Screw that. I bought a nice N comfy Leather GSR ****
JunkeeCrx's Avatar
New User
Thanks.
19mm socket w/extention. time: 5 minutes
Old Jan 7, 2002 | 08:45 AM
Todd00's Avatar
Go to BestBuy and buy both adapters, into the radio and into the oem wiring harness.
The radio sits in the dash fine, but you do need to find a way to secure it in the back so that it won't come flying out.
Old Jan 7, 2002 | 08:54 AM
Mugen Dom's Avatar
wut did u do to secure it
Old Jan 7, 2002 | 09:45 AM
TypeR0207's Avatar
I got a cheapy short shift kit, and put that **** on it.
I was mistaken in thinking it would be the size of my old Momo Cobra **** I had ...... but it works for me. The shifter is blue anodized though, so it looks kinda funky with the clear **** .......
Old Jan 7, 2002 | 10:54 AM
Todd00's Avatar
Just rigged up a way to hold it secure near the back. Once you're back there looking, you'll see a few things jump out at you. It's pretty simple.
Old Jan 7, 2002 | 11:24 AM
marty's Avatar
bad *** pair of jeans brad.
haha
[Modified by MugenEF7, 8:24 PM 1/7/2002]
Josh Z.
12
Nov 20, 2011 08:41 AM
ukrkoz
May 24, 2009 09:17 AM
reckz
Apr 3, 2009 02:23 PM
digitalVinyl
Oct 15, 2006 09:47 PM
johnclaunch
Jan 28, 2006 05:04 PM
