tranny grind?
Old Dec 26, 2004 | 10:08 PM
91H4hatch's Avatar
Default tranny grind?
i just got a new clutch in my 91 hatch. b4 the new clutch there was a grind shifting into 3rd, after the new clutch was installed the grind is still still there. how do i fix that grind?
Old Dec 26, 2004 | 10:28 PM
sohcvtec66
Guest
Posts: n/a
Default Re: tranny grind? (91H4hatch)
what kind of tranny or u using, cable or hydo?
cable is more likely to grind at higher rpm's, buy new tranny, new gears, throw out bearing my be bad, did u refill the tranny oil...lol
Old Dec 26, 2004 | 10:29 PM
Beyond Imagination's Avatar
clutch has nothing to do with the gear grind. try using GM syncromesh. i used that in my tranny and it helped out a bit.
Old Dec 26, 2004 | 11:22 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: tranny grind? (Beyond Imagination)
Synchromesh is t3h 5h1zn1t.
Old Dec 27, 2004 | 04:49 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91H4hatch &raquo;</TD></TR><TR><TD CLASS="quote">how do i fix that grind?</TD></TR></TABLE>
Replace the 3rd gear synchronizer.
Or buy a new transmission . . . it's usually cheaper.
Old Dec 27, 2004 | 06:51 AM
DaX's Avatar
DaX
Loved
Community Favorite
GM Synchromesh is a slight fix, but you must continue to baby the tranny and not try to shift at abnormally high RPM's. The best fix is to replace the worn synchros. Contact Gear-Speed...they have carbon synchros for just about every application and they run around $200 for the full set.
Old Dec 27, 2004 | 08:12 AM
91H4hatch's Avatar
its a cable trans. maybe ill look into a DX 5 speed trans. iv already tried heavier oil. how much $ we talkin for one of those, and it will fit my D15 right?
phelpsj2
May 18, 2010 03:40 PM
13link EG
Jul 30, 2005 08:53 PM
Manolo
18
May 18, 2005 09:21 AM
four-eyez
May 1, 2005 11:59 AM
EckoChronicles
Nov 6, 2002 03:07 PM
