Will LS throttle body bolt up to GSR or B16 intake manifold???
Old Dec 26, 2004 | 09:35 PM
Mr.DC2TurBo's Avatar
Default Will LS throttle body bolt up to GSR or B16 intake manifold???
I'm about to convert my LS to ls vtec and I was wondering if I can reuse my stock ls throttle body with a Skunk 2 manifold for a gsr or b16 without modification? Is it straight bolt on? Also, can i transfer my stock sensors from LS to the new vtec manifold?
Old Dec 27, 2004 | 05:49 AM
Rod.'s Avatar
Default Re: Will LS throttle body bolt up to GSR or B16 intake manifold??? (Mr.DC2TurBo)
Yes, you can use the Throttle body on a b16 manifold. It worked for me with no leaking problems and the stock sensors work. I had to modify my ls throttle cable bracket to work on my skunk b16 intake manifold.
Old Dec 27, 2004 | 08:30 AM
DC2tuner's Avatar
I Think I'm TOO White For This Thread
Default Re: Will LS throttle body bolt up to GSR or B16 intake manifold??? (redturbocivic)
wont work on gsr
Old Dec 27, 2004 | 09:40 AM
Default Re: Will LS throttle body bolt up to GSR or B16 intake manifold??? (gsrpwr2004)
LS won't fit on gsr skunk 2 intake manifold? Can anyone be sure on this one bc that's the head I purchased for my conversion.
Old Mar 22, 2010 | 04:21 PM
turboman2.2's Avatar
no it wont even fit, i have b18b1 throttle body and a b16 im, the throttle body had the lil sensor thing on the bottom, in which on the b16 it goes on the im, it also sits a lil over the edge on the bottem, so the lil passages in the throttle body will show on the bottem, idk if that will casue leaks, but i am not gon take that chane, i am just gon buy a b16 tb
ryanevansoh
Mar 22, 2010 04:22 PM
BOOSTED_JDM_DB8
Apr 13, 2006 02:42 PM
Rhythm
Feb 16, 2006 06:37 PM
Ri5e
Jul 26, 2002 09:28 PM
