Are the 2000 integra Type R intake cam the same as the 2001 type R cam (CTR SPEC)
Old Jan 6, 2002 | 02:47 PM
Tyson Ballou's Avatar
Default Are the 2000 integra Type R intake cam the same as the 2001 type R cam (CTR SPEC)
Im pretty sure the 2001 usdm type r intake cam has almost identical specs to the jdm ctr intake cam, but im wondering if the 2000 usdm type r intake cam is the same thing. Thanks
Old Jan 6, 2002 | 02:52 PM
1fastGSR's Avatar
New User
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (Martin De Porres)
some people swear that they are the same, but I do not think anyone knows for SURE, but they are better than 97-98 ITR's. Some people say that 00-01 ITR cam have 2 more degrees of duration than 97-98 ITR's, but still 1 deg. duration less thab CTR's.
and yes, 00-01 ITR should have the same cams. This can easily be verified by calling the dealership and getting a part number.
Old Jan 6, 2002 | 05:44 PM
JohnnyBoy's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (1fastGSR)
Try a search...Someone profiled them and it looked to be that it was the same.
Old Jan 6, 2002 | 05:52 PM
ITR764's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (JohnnyBoy)
mike k has some very good info on this issue... try im'ing him.
Old Jan 6, 2002 | 08:38 PM
Mike K's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (ITR764)
I think there may be a 1 degree difference between the 01 R and the CTR intake cams.. but I am not 100% sure.
I know for a fact the 01 R cams have 3 degrees up on the 97/98 intake cam.
Either way, IMO.. 3 degrees ain't **** if you got a set of cam gears and a V-AFC.
Old Jan 6, 2002 | 11:10 PM
Type-Rare#1248's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (Mike K)
if the 2001 type r cams are more aggressive than other years, why do they have same hp ratings...does that mean the 2001 type r's are faster??
Old Jan 7, 2002 | 02:18 AM
ingrate's Avatar
25 Year Member
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (Type-Rare#1248)
no.. it's probably just to compensate for stricter emissions equipment
Old Jan 7, 2002 | 03:08 AM
ITR764's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (In7egrity)
i'v heard that is the same for the 2000 and the 2001. they have tighter emissions crap so to be able to put out the same power the use ctr intake cams in them?
[Modified by ITR764, 7:09 AM 1/7/2002]
Old Jan 7, 2002 | 05:21 AM
98R #448's Avatar
I agree with Mike K. Who really thinks a 01typeR is faster than a 97-98??
Old Jan 7, 2002 | 05:23 AM
98R #448's Avatar
I agree with Mike K. Why would 01 type R be faster than a 98 in the first place? Its the same shyt. Maybe the black ones are the real sleepers
Old Jan 7, 2002 | 02:18 PM
JohnnyBoy's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (98R #448)
It would be faster because generally they dyno 10hp more than the 97-98 R's You always see plots of 170-175 for the '01's and 160-165 for the older ones...
Old Jan 7, 2002 | 02:19 PM
what type of stricter emission equipment...i own a 2001 ITR; what can i do to make the emission equipment similar to the ITRs in other years?
Old Jan 7, 2002 | 02:35 PM
B2FiNiTY's Avatar
Always? I haven't seen any stock 170-175...
Old Jan 7, 2002 | 03:36 PM
Big Teggie's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (B2FiNiTY)
I heard the 00-01 got better cams becuase they added ac stock. Which takes a bit of power fron the car even if not running, so better cams would make up for the little difference.
Old Jan 7, 2002 | 06:12 PM
1fastGSR's Avatar
New User
he's just BSing you!! Go to the dynocenter. They all make the same whp.
Old Jan 7, 2002 | 06:14 PM
1fastGSR's Avatar
New User
I would call that test "ingeneous", BUT certainly not accuarte.
Old Jan 7, 2002 | 06:19 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
hey guys, does the black ITR have different cams than the yellow one?
Old Jan 7, 2002 | 06:37 PM
sgT's Avatar
sgT
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (Ross)
Yes, the yellow one is faster because its a faster color.
Old Jan 7, 2002 | 06:39 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (sgT)
nah it's just that faster drivers have the yellow. black R owners are pussies who drive slow so as not to be noticed!
Old Jan 8, 2002 | 03:28 AM
ITR764's Avatar
yellows are slower cause of that loud azz color has more wind drag.
Old Jan 8, 2002 | 10:34 AM
1fastGSR's Avatar
New User
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (George Knighton)
ALL ITR's are OBDII
Old Jan 8, 2002 | 10:38 AM
maggsgsr's Avatar
And if you notice the newer R's get better times!!97 15.3 01 14.8.Atleast thats what the magazines claim.
[Modified by maggsgsr, 7:40 PM 1/8/2002]
Old Jan 8, 2002 | 10:44 AM
Mike K's Avatar
Default Re: Are the 2000 integra Type R intake cam the same as the 2001 type R cam (maggsgsr)
magazines also have mario andretti driving.
Launchpad
Oct 11, 2005 04:23 PM
westdoor
Apr 9, 2003 10:26 PM
dingusjt
Mar 21, 2003 12:06 PM
(teh)H2OUUP2
Oct 29, 2002 12:53 PM
SupersonicBlueGS-R
Jan 3, 2002 11:01 AM
