Exhaust upgrade
I'm installing a JDM DC Sport header and a 2.5" Carsound cat. From the cat back will remain stock ITR exhaust. What flanges will be needed? Should I use the OEM flange? What about the out end of the cat, will I need to order a flange for that side? Also the bracket that is needed for the OEM JDM header, is it needed for the DC Sport?
For the stock exhaust, you need a 3 bolt flange. You can find these on kteller.com. Find the appropriate size for the outlet size of the cat to match up against the stock b pipe. Don't forget the gasket.
As an aside, someone in the classified has a 2.5" mugen TL exhaust set up for 500 clams. Wish I would of seen this before getting a T1R bpipe...
DannyITR
Feb 29, 2004 08:56 AM
Hasboro
Nov 3, 2003 06:15 AM
BSQ
Jul 13, 2002 11:48 PM
ninjaman
Aug 1, 2001 04:49 PM
