if a swap a manual B18c into a auto 93 hatchback what is needed.....
Old Jan 6, 2002 | 02:13 PM
lazyvietboi's Avatar
Default if a swap a manual B18c into a auto 93 hatchback what is needed.....
if a swap a manual GSR into a auto 93 hatchback what is needed to make it into a manual? is there alot of wiring to do? easy swap or what? any info on manual b18c swap into a auto hatchback.
i did a search but it wasnt helpful for me.
Old Jan 6, 2002 | 04:28 PM
Jared's Avatar
Default Re: if a swap a manual B18c into a auto 93 hatchback what is needed..... (lazyvietboi)
Pretty straight forward swap using all electronics, mounts, etc.. from a 94-95 Integra. However, you will need to remove the transmission mount from the from rail and reposition it because the auto mount is different from the manual mount. you will also need to run all the clutch lines, as well as mounting the pedal and the master cylinder.
smartgreen007
Transmission & Drivetrain
May 14, 2010 03:12 PM
limit
Jan 26, 2009 12:27 PM
Silspeg6
Jan 22, 2009 10:19 AM
YEE*MagicEK20kombobomber
May 21, 2005 10:19 AM
