OT: CD install issue
Old Dec 26, 2004 | 04:19 PM
.RJ's Avatar
.RJ
Default OT: CD install issue
https://honda-tech.com/zerothread?id=1095856 - any of you stunnas know whats going on there?
Old Dec 26, 2004 | 04:30 PM
jaa1311's Avatar
Default Re: OT: CD install issue (.RJ)
could it be a problem w/ the laser? I know on say a ps2 it would work yet when trying to play a cd it would not read. I fixed this by increasing the voltage going to the laser. Dunno if this helps but its worth a thought
Old Dec 26, 2004 | 05:27 PM
Haleiwa-Brando's Avatar
Default Re: OT: CD install issue (jaa1311)
Let's hear what head unit your using.
How about the obvious? Volume is up? Using an amp? If your using an amp did you plug in the signal wire? Properly? Any wire grounding out? Is there crackling coming from the speakers? Did you press the "Loud" button on the deck? Fuses? If it's a newer model deck there should be a couple fuses on the back of the deck.
Aloha,
Brandon
Old Dec 26, 2004 | 05:29 PM
Chris F's Avatar
Default Re: OT: CD install issue (Haleiwa-Brando)
Have you tried replacing the car with something a little more (H)onda?
Old Dec 26, 2004 | 05:30 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Let's hear what head unit your using.</TD></TR></TABLE>
Its in the post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">How about the obvious? Volume is up? Using an amp? If your using an amp did you plug in the signal wire? Properly? Any wire grounding out? Is there crackling coming from the speakers? Did you press the "Loud" button on the deck? Fuses? If it's a newer model deck there should be a couple fuses on the back of the deck.</TD></TR></TABLE>
The radio works just fine, sounds great - just no sound when I play a CD
Old Dec 26, 2004 | 05:34 PM
It's got to be your laser. I'm sure all the information is in your other post. However, I'm a lazy piece of **** today and do not feel like looking. If it's a new unit, take it back. If it's used then get a new one. Sounds like the lazer went **** up on you, which just recently happened to me. Car decks are built to take abuse and shock but if it happened just right you could knock the lazer loose, break the track that it's on, loosen a wire off of it...
Aloha,
Brandon
.RJ's Avatar
.RJ
brand new in box off ebay
Heading over to Brian's place now, that will rule out a faulty player
Old Dec 26, 2004 | 05:36 PM
Brian*'s Avatar
Hurry up! It's almost past my bedtime. Oh wait, I don't work again till the 4th
Brian
Old Dec 26, 2004 | 05:38 PM
Default Re: OT: CD install issue (Brian*STi)
I say that the shipping company either dropped it, or you dropped it. Either way, sounds like your up **** creek and you forgot your paddle.
Aloha,
Brandon
Old Dec 26, 2004 | 06:09 PM
.RJ's Avatar
.RJ
Not a problem with the CD player... something to do with that wire I did not use
RJ - digging through bmw shop manual now
Old Dec 26, 2004 | 06:54 PM
.RJ's Avatar
.RJ
Success
Have to wire the remote power lead to the wiring harness so it sees a constant +12v
danteisme
Audio / Security / Video
Oct 31, 2005 12:24 PM
92-LS-Civic
Oct 7, 2005 09:06 AM
2+2Door
Jul 12, 2005 03:21 PM
CivicSiRracer69
Dec 26, 2003 07:28 AM
zcivicz
Mar 24, 2003 05:04 PM
