CD Install Issue ( Nackamichi CD-400 )
Old Dec 26, 2004 | 04:07 PM
.RJ's Avatar
.RJ
Default CD Install Issue ( Nackamichi CD-400 )
Installing a CD player in my 94 325is, everything went well, all the speakers work fine except there is no sound when I play a CD - it plays (the track/timer works, I can hear it spinning) I just get no sound but the radio is fine. Faulty head unit?
Old Dec 26, 2004 | 04:25 PM
Brian*'s Avatar
Default Re: CD Install Issue (.RJ)
If I recall from my 325i, it's something to do with the factory crossovers for the stock speakers. I don't much more than that, but maybe it'll get you in the right direction.
Brian
Old Dec 26, 2004 | 04:26 PM
.RJ's Avatar
.RJ
Default Re: CD Install Issue (Brian*STi)
HRm.... weird. If there's a problem w/ the front speakers, why would the radio work and not the cd player?
Old Dec 26, 2004 | 04:35 PM
Brian*'s Avatar
Hmm, nevermind then
I have a CD-45Z you could try if you wanted to. I lost the harness for the back so I can't really use it. I'm sure the harness on yours would work with it.
Brian
Old Dec 26, 2004 | 04:39 PM
.RJ's Avatar
.RJ
PM me your phone # I'll come over tonite
Old Dec 26, 2004 | 05:27 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Installing a CD player in my 94 325is, everything went well, all the speakers work fine except there is no sound when I play a CD - it plays (the track/timer works, I can hear it spinning) I just get no sound but the radio is fine. Faulty head unit?</TD></TR></TABLE>
Where are the amps? Are these powered crossovers?
It COULD BE that the antenna up/down switch is the culprit. Does it have a power antenna or power antenna line? Some radios will put the antenna down when using the CD player, and if you have an amp that's switched on/off by that, the amp will turn off.
Something along those lines?
-Chris
[e] less sucky wording
Old Dec 26, 2004 | 05:31 PM
.RJ's Avatar
.RJ
Default Re: CD Install Issue (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">It COULD BE that the antenna up/down switch is the culprit. </TD></TR></TABLE>
Interesting - there was something antenna related that came off the OEM tape deck that I did not use with the new one - just left it hanging back in the dash.
Old Dec 26, 2004 | 06:55 PM
.RJ's Avatar
.RJ
Success
Have to wire the remote power lead to the wiring harness so it sees a constant +12v
Old Dec 26, 2004 | 07:42 PM
Chris F's Avatar
Old Dec 29, 2004 | 06:20 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Have to wire the remote power lead to the wiring harness so it sees a constant +12v </TD></TR></TABLE>
Ryan,
Did you wire that to a ignition-switched 12V source, or straight from the battery? If that's a switch for amps, you would want it ignition switched or your battery might die after a day or two.
Old Dec 29, 2004 | 06:26 AM
.RJ's Avatar
.RJ
Its ignition switched on.... service manuals own
Triptweeze
17
Mar 2, 2008 04:43 PM
DrunkNRacer
Audio / Security / Video
Apr 27, 2005 07:25 AM
mnjh94
Nov 12, 2004 07:47 PM
wtfitzphat
Jul 19, 2004 04:31 PM
WuShu
Oct 5, 2001 10:22 AM
