EG radiator into ED mount fabrication
Old Dec 26, 2004 | 04:07 PM
xci_ed6's Avatar
Default EG radiator into ED mount fabrication
I'm working on this currently. I was going to add them to my (aftermarket) crossmember, but that is a stressed member, and is more likely to flex independantly of the top mount...isn't it? So I have been thinking of adding them to the radiator support instead.
Which seems like a better location, the rad support or crossmember?
Old Dec 26, 2004 | 10:05 PM
sporkcrx's Avatar
Default Re: EG radiator into ED mount fabrication (krustindumm)
Doesn't jimfab (or one of the companies that makes the xmembers) have an optional mount for that? I'm 90% sure they do, so I'd think the crossmember would be fine.
Old Dec 27, 2004 | 08:09 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">Which seems like a better location, the rad support or crossmember?</TD></TR></TABLE>
EG rads are fairly tall - i think your only option is the crossmember. i still had to modify my hood a little bit to get it to fit on my CM.. it will be fine.
Old Dec 28, 2004 | 02:32 PM
Steve91's Avatar
Put the mounts on your cross member. If you want to really do it nice, fab it up so you can use the two factory rubber mounts than the radiator pegs sit into. That will allow the radiator to move a bit.
Old Dec 28, 2004 | 05:10 PM
xci_ed6's Avatar
Default Re: EG radiator into ED mount fabrication (Steve91)
thatnks for the responses. Yeah, my plan was to drill out the welds on the factory mounts and either extend them down w/ brackets or rivit/weld them to the crossmember.
EFstyle
Nov 12, 2008 09:43 PM
91SI_SON
Oct 15, 2008 10:08 AM
whole9
Mar 31, 2007 03:23 AM
regime
18
Dec 17, 2004 07:43 AM
D16Z6racing
Sep 6, 2002 08:23 PM
