Wicked Stage2 vs BC4
I really can't decide if it will be worth getting BC4 cams since I already have Wicked Stage2 cams here. The engine has not been dynoed since I was running a stock B16A head, cams etc. so I don't know how my power band will be and I'm still missing my RLZ head. I'm setting the rev limit to 8500 RPM since I'm on stock B20 sleeves bored to 85 mm. I'm pretty sure the Wicked cams will be making power above 8500 RPM with the crazy stage3 port from Brad. As I can see from the graphs floating around the BC4's will make more power below 8500 RPM and may be worth checking out. I might do a Wicked vs BC4 test if I can get a good deal on the BC4's.
Other thoughts about this would be great...
The specs are:
B20B3 block bored/honed to 85 mm.
IB Spec Wiseco 12.0:1 pistons
Probe Ultra Light rods
RPM Service 72 mm TB
Wicked IM
3" short ram with velocity stack
RLZ Stage3 B16A head
IB Spec valvetrain
IB Spec valves
SMSP B20VTEC header
Hondata S200
The specs are:
Wicked IM
IB Spec valvetrain
IB Spec valves
SMSP B20VTEC header
Hondata S200
