question about MAP sensor...
Old Jan 6, 2002 | 01:21 PM
b18bvudoo's Avatar
New User
Default question about MAP sensor...
i'm trying to wire up my mf2 and i need to know what color wires corresponds to what signal on the MAP sensor. for the map sensor which color wires are the +5v and which is the pressure input signal wire. theres a 3rd wire too which i'm not sure what it is. thanks for any info.
edit: for b18b
[Modified by vudoo666, 2:21 PM 1/6/2002]
Old Jan 6, 2002 | 02:00 PM
boosted3g's Avatar
Default Re: question about MAP sensor... (vudoo666)
green/white- ground
white- signal
yellow/red- 5V
Old Jan 6, 2002 | 02:17 PM
b18bvudoo's Avatar
New User
Default Re: question about MAP sensor... (boosted3g)
thanks a lot boosted
Old Jan 6, 2002 | 02:21 PM
JM Performance's Avatar
I'm running the MF2 in my car. Your supposed to use a new, seperate MAP sensor. Because answer me this: How will you keep your ECU from seeing boost, but still let the MF2 see it?
[Modified by 00SilverLS, 6:21 PM 1/6/2002]
Old Jan 6, 2002 | 04:19 PM
b18bvudoo's Avatar
New User
Default Re: question about MAP sensor... (00SilverLS)
hmm..yor right. i guess i wasnt thinking.
airwalk07143
Mar 18, 2006 05:55 PM
Gant
May 18, 2005 08:47 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
